Aussie ae86 rally car
11-09-2008, 05:58 PM
Post: #41
What is your tacho? It looks like a stock one, but in the last pic I can see something like carbon fiber pattern on the background. I really like it!
11-09-2008, 10:48 PM
Post: #42
what suspension are u using? can you give name, price or links?
AE86! love love love! Hankiewicz Rally Team |
11-09-2008, 11:06 PM
Post: #43
http://www.dmshocks.com/
as for how they perform, well ill tell you after the weekend and the dash is just from a jdm kouki ae86, you can find them for almost nothing on yahoo.jp..from memory i paid about $70 aud delivered (about 30 pounds) |
11-09-2008, 11:56 PM
Post: #44
thx...and what was the price?
got little problem with yahoo - those signs are a little bit hard to read regards AE86! love love love! Hankiewicz Rally Team |
11-10-2008, 06:17 AM
Post: #45
they are really a made to order item, not off the shelf. They werent that much, $1500 Aud for the bare struts, no tops, no stub axles (i had to machine the stub axles off an original strut and press them onto place on the dms version)
11-22-2008, 06:52 AM
Post: #46
Looks great! I wish I could say my car was done.... but... its not. Its not even half done..... School... work.... slow work.... blah.
your car looks awesome though. There's only one problem I see. Your steering wheel is on the wrong side! Wow, I could have sworn I had an account here... I guess I'm the new guy |
11-25-2008, 03:49 AM
Post: #47
Looks the goods. What make are the wheels you've got in the earlier pics? The ones that scream rally car.
Oh, and how did your event go? |
11-28-2008, 01:13 AM
Post: #48
That cage is a work of art, amazing
12-14-2008, 02:38 PM
Post: #49
Well, come on with that update then.
12-14-2008, 03:04 PM
Post: #50
SHHHH Aram!
Sorry, those pics were posted up a few days before it went in its first rally (and mine) Car did very well, on a shakedown on a friends farm (pretty much a goat track) the car had a slight know on the lhf...we got it in the air, pulled the bottom bolts off the strut ...it shot out of the car...the captive nut holing the shock in the housing had worked its way loose...very lucky not to bend a $650 insert I also found, ever with the limiting valve wound to full rear, it still locked up the fronts, and only fronts.. So it couldnt be fixed for the event so i had not alot of rear brakes, just had to change the way i drove...back it in One major problem i had leaving service is the trip metre didnt work, which is essential as this rally was not pace noted, it was the first time we been on the stages, so everyone was given the same road book, with limited notes...and a distance to each note. My car essentially had no way of telling how far it went...so the navigator (to his credit he is state champion) was calling out notes unsure if they were in the right spot. Didnt get that fixed till the 1st service, even then it was intermittent. turns out something had hit the speedo cable and torn it off the box..we got it connected somehow again, but it was more than stuffed. Finished the rally 7th, out of 18, cars with much more power and much more km's in the field . Notable damage was I hit a rock 4km into stage one, very lucky not to puncture. but Bent the diff housing very badly, 10mm toe OUT from one hit, it made the car hard to drive...very taily. so this is the fix. Was put in a lathe and the ends were cut off, and 3mm sleeves were welded down the housing. Then was welded back together, made absolutely square and 6mm by 50mm steel welded along the bottom of the housing. Shits getting serious now If i bend this, ill be surprised. Mind the shit pics, only took them with my phone. Otherwise, pics from the rally. and a small vid, resonates well off the trees i have a list a mile long to do over the summer. biggest thing is a pedal box going in[/video] |
nzae86's AE86 Levin Tarmac rally car build Project 1 | nzae86 | 30 | 56,092 |
04-30-2013 07:28 AM Last Post: nzae86 |
Spanish Corolla AE86 Rally car On board | leckter | 5 | 8,513 |
07-30-2011 05:14 PM Last Post: leckter |
Spanish tarmac Rally Car | leckter | 4 | 7,156 |
06-18-2011 02:59 PM Last Post: leckter |
Road Rally AE86 | Garth | 1 | 3,917 |
08-11-2009 12:14 AM Last Post: Garth |
Road Rally AE86 | Garth | 3 | 5,178 |
06-20-2007 11:43 PM Last Post: Garth |
