Axle/wheel hop?
09-08-2007, 10:29 PM
Axle/wheel hop?
I am experiencing quite a lot of axle/wheel hop when doing burnouts/donuts.
(had this also before the cusco lsd)
Like the whole rear axle start to shake and jump.
Tried setting my shocks soft/hard...no difference.
Also tried different tires...still there.
I read somewhere that traction brackets seem to help this problem.
This are the mods on the rear axle:
TRD 6k springs
Tokico HTS schoks
Cusco 2way lsd
Everything else is stock.
Got prothane bushings here for the 4links and getting a panhard rod soon.
But I was wondering if anybody knew where the problem lies exactly.
09-08-2007, 11:48 PM
Axle/wheel hop?
Lateral rod bushing need replacing, 100%, I see you have a prothane kit which will solve this. Wave
[Image: AEU86 AE86 - Axle/wheel hop?]
09-09-2007, 06:41 AM
Axle/wheel hop?
New bushings. The old ones are so bad they are binding and loading/unloading under acceleration causing wheel hop.
Traction brackets will also help a great deal by forcing the rear end to 'plant' the tires after correcting your suspension geometry from being lowered.
So, do both Smile
Andrew
09-10-2007, 12:50 PM
Axle/wheel hop?
Traction brackets will INCREASE wheel hop (suspension basics).
09-10-2007, 01:31 PM
Axle/wheel hop?
jamiemirror Wrote:Traction brackets will INCREASE wheel hop (suspension basics).
How so Jamie?
09-10-2007, 01:46 PM
Axle/wheel hop?
Have it explained on paper, need to make pics and attach here.
More anti-squat --> more brake wheel hop.
http://www.raceglides.com.au/TechInfo.htm
Interesting reading btw.
09-10-2007, 06:18 PM
Axle/wheel hop?
Seems to concur with most reviews I've seen of traction brackets.. Tsuchiya himself likes his car better without them too.
09-10-2007, 06:19 PM
Axle/wheel hop?
Thanks for the replies guys. Going to try the new bushings and adjustable rod first and see if it helps.
@Jamie, if that is the case then I shouldn't have any wheelhop since my 4link bars are pointing up like in the first drawing. But I think I'll get some cheap traction brackets in a month or so to and see what happens. Smile
And are the rca's ready? I pm'ed you about them. Trying to get my car in a decent shape because my suspension geometry is all over the place... haha Banging head
09-10-2007, 09:11 PM
Axle/wheel hop?
Pics from the book (very poor quality):
09-11-2007, 07:45 AM
Axle/wheel hop?
the books and URLs are about braking wheel hop. isnt that opposite of acceleration??
rust in piece ricing team.
  AE86 rear axle weight megabob 11 19,612 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 1,304 10-24-2023 12:20 PM
  Rear axle options Dino86 13 13,634 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,921 12-21-2016 09:37 PM
Last Post: bozu
  wider rear axle,track width,suspension questions ditn 6 9,272 10-18-2016 11:50 AM
Last Post: fantapants
