Axle width
09-11-2023, 10:10 PM
Axle width
I have the chance to buy a modified Mitsubishi axle to fit an AE86
It is 50mm wider than the Toyota one currently fitted.
Does anyone know if it will need wider arches on the car?
Thanks
10-24-2023, 12:20 PM
Axle width
I assume it depends on the wheels & tyres you 're going to use and how much your car will be lowered.
50mm wider means 25mm earch side. That's almost equal with going from stock to 15x8 ET0 wheel size.
[Image: AEU86 AE86 - Axle width]
Follow: The story of my AE86
  AE86 rear axle weight megabob 11 19,673 03-29-2024 11:18 AM
Last Post: FanIsHere
  Rear axle options Dino86 13 13,673 01-08-2018 10:19 PM
Last Post: ditn
  Rim width. Which is best.... Dino86 5 7,033 01-07-2017 03:09 PM
Last Post: Dino86
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,927 12-21-2016 09:37 PM
Last Post: bozu
  wider rear axle,track width,suspension questions ditn 6 9,286 10-18-2016 11:50 AM
Last Post: fantapants
