Axle width
09-11-2023, 10:10 PM
Axle width
I have the chance to buy a modified Mitsubishi axle to fit an AE86
It is 50mm wider than the Toyota one currently fitted. Does anyone know if it will need wider arches on the car? Thanks An analogue brain in a digital World |
10-24-2023, 12:20 PM
Axle width
I assume it depends on the wheels & tyres you 're going to use and how much your car will be lowered.
50mm wider means 25mm earch side. That's almost equal with going from stock to 15x8 ET0 wheel size. ![]() Follow: The story of my AE86 |
| AE86 rear axle weight | megabob | 11 | 22,215 |
| Rear axle options | Dino86 | 13 | 16,991 |
| Rim width. Which is best.... | Dino86 | 5 | 8,363 |
| Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 4,609 |
| wider rear axle,track width,suspension questions | ditn | 6 | 11,327 |
![AEU86 AE86 - Axle width [Image: AEU86 AE86 - Axle width]](https://i.ibb.co/MhLrFLH/45782267-2164710247101236-2051748599338893312-n.jpg)
