B Tune Swift Front & Rear Springs
05-30-2006, 02:47 PM
Ivan141 Wrote:You could try having custom springs wound with a number of very closely spaced windings. This will give you an area on your spring with very low springrate that will let the car sit a bit lower but still keep the spring captive at full extension. The trouble is that you would need a lot of these windings if you want 8kg/mm, leaving the part of the spring that does all the work with little travel.
Yes, you’re right about custom springs. But, it’s very hard to make it right from one go, especially if you don’t have coil-overs to correct the desirable ride height. You have to put them on several times and to fix them again and again every time to achieve perfection. It takes time and money.
Fun is not the straight line!
Messages In This Thread
[] - Ivan141 - 05-30-2006, 11:39 AM
[] - max_ae86 - 05-30-2006, 12:01 PM
[] - Ivan141 - 05-30-2006, 12:27 PM
[] - max_ae86 - 05-30-2006, 12:53 PM
[] - NoHachi - 05-30-2006, 01:30 PM
[] - max_ae86 - 05-30-2006, 01:50 PM
[] - Ivan141 - 05-30-2006, 02:26 PM
[] - max_ae86 - 05-30-2006, 02:34 PM
[] - max_ae86 - 05-30-2006 02:47 PM
[] - Ivan141 - 05-30-2006, 03:05 PM
[] - max_ae86 - 05-30-2006, 03:53 PM
[] - max_ae86 - 06-05-2006, 10:27 AM
[] - max_ae86 - 06-06-2006, 09:40 AM
[] - SYM - 06-08-2006, 06:45 PM
  HKS valve springs totta Crolla 3 2,124 05-25-2022 10:24 PM
  Springs from other vehicles?? FanIsHere 16 14,375 05-17-2016 09:12 AM
Last Post: FanIsHere
  S13 Front brakes in AE86 rear heshan 25 28,121 02-01-2014 12:37 PM
Last Post: heshan
  3rd door support gas springs (stay) - worn out max_ae86 5 6,099 09-01-2013 03:20 PM
Last Post: Jezza_hr
  Valve springs length Vil 4 5,787 04-04-2013 07:41 PM
