BBBBRRRRR FREEZING
11-25-2006, 04:14 AM
BBBBRRRRR FREEZING
Hi all,
Just wondering if you could shed some light on this for me,since i have had the car the heating hasn't worked.Any one got any ideas.Do the cables wear easily on these cars??or would the likes of a low temp sports thermostat have anything to do with it??
Big thanks in advance.....BBBRRRR Smile
The A.d.d Clinic
Automotive Detailing:
http://www.addperformance.ie
[email protected]
JDM Import specialist:
A.d.d - Ireland
11-25-2006, 11:10 AM
BBBBRRRRR FREEZING
Tjeck the cables to the heater, mine fell of the heater console last winter.
11-25-2006, 02:55 PM
BBBBRRRRR FREEZING
Will do cheers,anything else??
The A.d.d Clinic
[email protected]
A.d.d - Ireland
11-25-2006, 04:43 PM
BBBBRRRRR FREEZING
a broken thermostat possibly...
11-25-2006, 05:57 PM
BBBBRRRRR FREEZING
Cheers Ivan,will have lots of fun tomorrow checking things Smile
The A.d.d Clinic
[email protected]
A.d.d - Ireland
11-25-2006, 06:52 PM
BBBBRRRRR FREEZING
Yeah I got the same problem in my current daily driver. Its f*#&$ing cold inside.
Have you checked if your cable is atually conected to the valve undet the bonnet? if not, you can turn it on, from undet the bonnet.
I changed the thermostat, but it still didnt change anything.
But when I got the car, the radiator was stuffed, and patched up with some kind of play doe, and there was a bottle of radiator-leak-fix in the boot, so I'm thinking 'IT' together with some other stuff that may have broken off the radiator, has clogged up the heat exchange for the heater.
H
[Image: AEU86 AE86 - BBBBRRRRR FREEZING]
Koukis - Red, Silver/Gray,
11-25-2006, 09:06 PM
BBBBRRRRR FREEZING
cheers mate,good reply you got me gigglin,think i've sniffed to much car fumes....LOL Confused Confused Smile
The A.d.d Clinic
[email protected]
A.d.d - Ireland
12-03-2006, 07:41 PM
BBBBRRRRR FREEZING
My heater works but is a bit pathetic. I wouldn't mind making it a bit warmer in the car, any ideas?
12-03-2006, 10:34 PM
BBBBRRRRR FREEZING
Hi all,
Got my heating working finally,the cable had come off at the back of the heater control unit and also it was a bit frayed where the cable enters the car from the bulkhead.But it's all good now happy days...
Hi Jezza,the best thing to do is give the whole heating system a damn good servicing if you can yourself or get someone reliable to do for you.it's getting to the time of the year that you'll need all the heat you can get in the cars.
The A.d.d Clinic
[email protected]
A.d.d - Ireland
07-08-2007, 04:48 PM
BBBBRRRRR FREEZING
You wouldn't happen to have a copy of any service manuals for the AE86 heater? ive been wanting to recon mine for years but have no idea how or what to replace.
