BT 20V ECU for Big Port 16V (+ AE92 question)
05-02-2009, 02:26 PM
Hello.
I've got a big port 16V and 295cc blacktop injectors... I'm searching for AE92 hi-comp ECU and injectors (as alternative to aftermarket ECUs). And finally, today I've got an idea - can I swap the ECU with 20Vs one? Will I need to kill the VVT-i sensors? Please, tell me what you think. Thank you!
Hurray!
1972 Ford Taunus (drift project)
1984 Toyota Celica AA63 (4AGE, 5MT, IRS)
05-02-2009, 03:27 PM
You cannot change ECU's like that, BT ECU wont work on 16v.
Go megasquirt/VEMS/other standalone ECU
05-02-2009, 04:06 PM
Even if I re-pin the wire for 20V ecu?
Okay, then, will re-pinned AE92 hi-comp ECU work?
05-02-2009, 05:53 PM
I think that the sensor and the signals of them are not the same!
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - BT 20V ECU for Big Port 16V... question)]
05-04-2009, 07:18 AM
Hmmm... so I should find a small port first gen 4AGE like your EE80? That is the only one possible to get swapped?
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,969 05-26-2024 07:40 PM
Last Post: totta Crolla
  Question about 4AG 20v Engine Block CHACAMAN 1 1,814 06-10-2022 05:17 PM
  Big wheel problems gh0st 16 8,881 11-15-2021 10:51 PM
Last Post: gh0st
  20v mains & big end bearing izanagi 9 10,765 12-26-2016 12:42 PM
Last Post: pack
  Small Port Swap Alex170984 1 4,340 11-21-2016 01:46 PM
Last Post: Alex170984
