BT 20V ECU for Big Port 16V (+ AE92 question)
05-02-2009, 02:26 PM
Hello.
I've got a big port 16V and 295cc blacktop injectors... I'm searching for AE92 hi-comp ECU and injectors (as alternative to aftermarket ECUs). And finally, today I've got an idea - can I swap the ECU with 20Vs one? Will I need to kill the VVT-i sensors? Please, tell me what you think. Thank you! 1972 Ford Taunus (drift project) 1984 Toyota Celica AA63 (4AGE, 5MT, IRS) |
05-02-2009, 03:27 PM
You cannot change ECU's like that, BT ECU wont work on 16v.
Go megasquirt/VEMS/other standalone ECU |
05-02-2009, 04:06 PM
Even if I re-pin the wire for 20V ecu?
Okay, then, will re-pinned AE92 hi-comp ECU work? 1972 Ford Taunus (drift project) 1984 Toyota Celica AA63 (4AGE, 5MT, IRS) |
05-02-2009, 05:53 PM
I think that the sensor and the signals of them are not the same!
**COROLLA EE80 - 4AGE 124HP** |
05-04-2009, 07:18 AM
Hmmm... so I should find a small port first gen 4AGE like your EE80? That is the only one possible to get swapped?
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 2,130 |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,608 |
Big wheel problems | gh0st | 16 | 8,075 |
20v mains & big end bearing | izanagi | 9 | 10,323 |
12-26-2016 12:42 PM Last Post: pack |
Small Port Swap | Alex170984 | 1 | 4,148 |
11-21-2016 01:46 PM Last Post: Alex170984 |
