BT head with ST block.
01-27-2018, 07:26 PM
I am considering this because I cant find a blacktop block. The car in question is a Corolla AE111GT. So I am using over my standard ecu and everything else.
how compatible is a blacktop head with a silvertop block. I know this much. I will need to use the blacktop pistons to avoid contact with the valves. 1)What about the oil pump? Can i use over my blacktop oil pump on the ST block? If i got the St block with its pump can I just exchange the sprocket? 2) Can I use my bt water pump? 3) what timing belt should I use? 4) If I use my blacktop pistons and connecting rod I will have to use crank? |
01-28-2018, 07:47 AM
(This post was last modified: 01-28-2018 09:44 AM by Project D.)
1) both oil pump will work. 13521-16060 sprocket for the BT pump; 13521-16010 for the ST (and any other 4AG)
2) Yes you can use your water pump (BT & ST share the same water pump pulley 16371-16030) 3) ST belt with ST oil pump (13568-19035), BT belt with BT oil pump (13568-19185) 4) Every 4AG(Z)E (16 or 20v) from 1987 to 2000 use the same crankshaft (13401-16020) By the way, if you are swapping all you internal parts, you don't need a 20V block, you could take ANY 4AGE block. Depending on where you live, it could make your life a lot easier. |
01-28-2018, 05:54 PM
(01-28-2018 07:47 AM)Project D Wrote: 1) both oil pump will work. 13521-16060 sprocket for the BT pump; 13521-16010 for the ST (and any other 4AG) I can also use the silvertop connecting rods with the BT pistons? I believe they are stronger. |
01-28-2018, 11:15 PM
Apart from the early 16v, every 4A-GE use a 20/42mm connecting rod. So yes, you can use any of them.
But if you already have a set of BT rods, go with those. (They are strong enough and lighter) |
01-29-2018, 12:38 PM
BT head with ST block. | |||
02-04-2018, 02:35 AM
02-06-2018, 06:27 PM
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,599 |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 86,678 |
05-05-2019 04:03 AM Last Post: Rocker100 |
How important are dowell pins on a 4age block | spill86 | 5 | 7,530 |
01-13-2016 11:19 AM Last Post: spill86 |
7 rib block for a bluetop head? | dinkers542 | 7 | 9,632 |
11-04-2014 01:44 PM Last Post: zenki |
20v block with 16v head and internals possible? | ditn | 3 | 6,943 |
08-12-2014 09:19 PM Last Post: ditn |
