07-14-2010, 10:53 PM
Post: #171
Yeah, I did find the info of the 20 vs 22 ribs on the propshaft. But I figured that since the wheelbase (and floorpan) of the Carina/Celica did not change between the A40 and A60 series it was most probable the same length.
I did see a different partnumber for the automatic vs manual propshaft, so those two are definitely different from each other...
07-14-2010, 10:57 PM
Post: #172
different length in gearbox and splines probably...
03-24-2014, 10:52 PM
Post: #173
Time to revive this tread I guess... Blush
After four years hoarding parts I ended up with way too much crap:
JDM head lights (still fixing those)
JDM tail lights (installed)
Extra body work (trunk, fenders, etc)
Koni shocks
TA40 T50 gearbox with TA40 propshaft
New rotors for the front (installed last year)
Waterpump (installed two years ago)
JDM gauge cluster
Various grilles, bumpers and other parts.
In the meanwhile I ordered a set of lowering springs, poly bushes (ae86 and I'll figure out which ones fit and which ones don't) and camberplates (KE70/TE71 items with 108mm between the holes).
Currently the Carina is garaged and I can do work on it from time to time. So I have a weekend next month (koningsday) were I can finally work a bit on the car and do the following:
replace springs/shocks
fit camber plates
replace bushes for polybush items
Another thing on the list of to-do is to scan a bunch of manuals for the Carina.
And I found a wiring diagram and a collision repair manual containing diagrams like this:
http://www.aeu86.org/viewtopic/detailed-...ns/t/2696/
03-28-2014, 11:46 AM
Post: #174
Goodies arrived! Hurray!
The camber plates are a perfect fit:
Can't wait to mount them on the car. Smile
03-28-2014, 02:49 PM
Post: #175
if you need help let me know Art
03-28-2014, 05:08 PM
Post: #176
you will need help and some american sized tools (or new nuts/bolts Tongue) to fit those camberplates, ask me how i know Sad
03-28-2014, 05:51 PM
Post: #177
You'll probably regret buying those polyurethane bushings after you've mounted them.. (because not racecar). Swapping bushings is definately a job that requires good access and some tools.. getting the old ones out can be a bit of a chore.
03-28-2014, 06:00 PM
Post: #178
The Doctor Wrote:you will need help and some american sized tools (or new nuts/bolts Tongue) to fit those camberplates, ask me how i know Sad
U sure? The ones i bought for the KP61 came with metric bolts, didnt have a problem with those. Unlike the GC coiloversleeve bolt (TX27 fit the allen bolt tho Big Grin)
03-28-2014, 09:11 PM
Post: #179
mine only had US sized allen bolts and nuts. And why they come with nuts and bolts is a mystery to me, fitting them was a real ballache, pressed in studs like the Cusco units is waaay better and easier.
04-01-2014, 04:31 PM
Post: #180
Ivan141 Wrote:You'll probably regret buying those polyurethane bushings after you've mounted them.. (because not racecar). Swapping bushings is definately a job that requires good access and some tools.. getting the old ones out can be a bit of a chore.
Yes and no: some of my current bushes are almost none existent as 30 year old bushes have their limitations. As the Carina is no longer in use as the family hauler and I mainly use it for "fun" I can do what I want with it and I definitely like to stiffen up the ride and get back that old hachi feeling. Tongue
Space and tools is something I need to arrange but if I can't persuade them I can always attack them with the good old flamethrower. Smile
The Doctor Wrote:mine only had US sized allen bolts and nuts. And why they come with nuts and bolts is a mystery to me, fitting them was a real ballache, pressed in studs like the Cusco units is waaay better and easier.
As they are from T3 that's a very viable case here. I'll first have a look which ones they are and get back to you if I need help. Wink
  Banpei's two door panda Trueno from Japan banpei 6 756 01-06-2025 08:31 PM
Last Post: Eircamae86
  Family man's ae86 fantapants 90 65,741 11-12-2023 01:06 AM
Last Post: fantapants
  My Carina TA60 crxman 17 19,882 01-09-2016 10:17 PM
Last Post: nyberrg
  Project "Roku-ju" TA60 Carina Motax 24 38,863 03-05-2014 10:21 AM
Last Post: Motax
  Carina TA60! evanger 7 15,422 10-23-2012 10:18 AM
Last Post: Lightning
User(s) browsing this thread: 28 Guest(s)
