09-16-2007, 01:12 AM
Post: #111
Perhaps the spring length is different, so what would lower an AE86, wont lower an AA63?
I cant go too low with mine, my sump is the lowest part of the car now. Sad
11-30-2007, 03:10 PM
Post: #112
Suffered two weeks from a weird noise which I couldn't pinpoint. With help of my neighbor I found out that my right front shock is leaking, so when fully compresssed it is bumping against something in the strut. Undecided
I was planning to put a set of konis under the car anyway, but I thought that would come in time (read: one year or so...) but it looks like I have to do that a bit earlier then. Sad
The big question is: are AE86 konis going to fit in the TA60 struts? Dumb question
And can I also use AE86 konis on the rear axle? Dumb question
11-30-2007, 03:48 PM
Post: #113
jep, Dennis runs AE86 koni's in his celica struts, so they should fit Smile
Rear: dunno exactly, but i think it will be possible, since the setup is the same Smile
11-30-2007, 04:09 PM
Post: #114
Thanks! Thumbs up!
Well, I showed you that the axle has different mounting points for the shocks: they are more or less a bit nearer to the center of the car. Undecided
11-30-2007, 04:34 PM
Post: #115
i do have got a set of Tokico blues if you want!
Maybe a cheap inbetween solution for you problem Wink
You can testfit the rears then Big Grin
11-30-2007, 10:48 PM
Post: #116
Tempting... Tongue
But I still think I'll go for the Konis: can get them quite cheaply. Smile
12-02-2007, 06:21 PM
Post: #117
Think I found the answer. Hurray!
Both the AE86 and TA60 have 48530 and 48540 as partnumber for the rear shock absorbers, only the TA60 has different mounting points. Smile
12-02-2007, 08:38 PM
Post: #118
are the whole partnumbers the same?
Because that first number says nothing more then: it's a shock Tongue
Even my Starlet rear shocks do have those numbers, it's the number after the dash that counts!
12-02-2007, 10:06 PM
Post: #119
The Doctor Wrote:are the whole partnumbers the same?
I thought they were the same, but I'll double check it then.. Wink
12-03-2007, 10:27 PM
Post: #120
Double checked: they are different in numbers. Undecided
However... The front shocks differ in numbers as well, so we won't know till I've put them under the carina. Wink
  Banpei's two door panda Trueno from Japan banpei 2 303 11-14-2024 02:00 PM
Last Post: r.ave
  Family man's ae86 fantapants 90 62,882 11-12-2023 01:06 AM
Last Post: fantapants
  My Carina TA60 crxman 17 19,160 01-09-2016 10:17 PM
Last Post: nyberrg
  Project "Roku-ju" TA60 Carina Motax 24 37,912 03-05-2014 10:21 AM
Last Post: Motax
  Carina TA60! evanger 7 15,172 10-23-2012 10:18 AM
Last Post: Lightning
