09-16-2007, 01:12 AM
Post: #111
Perhaps the spring length is different, so what would lower an AE86, wont lower an AA63?
I cant go too low with mine, my sump is the lowest part of the car now. ![]() |
11-30-2007, 03:10 PM
Post: #112
Suffered two weeks from a weird noise which I couldn't pinpoint. With help of my neighbor I found out that my right front shock is leaking, so when fully compresssed it is bumping against something in the strut.
![]() I was planning to put a set of konis under the car anyway, but I thought that would come in time (read: one year or so...) but it looks like I have to do that a bit earlier then. ![]() The big question is: are AE86 konis going to fit in the TA60 struts? ![]() And can I also use AE86 konis on the rear axle? ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
11-30-2007, 03:48 PM
Post: #113
jep, Dennis runs AE86 koni's in his celica struts, so they should fit
![]() Rear: dunno exactly, but i think it will be possible, since the setup is the same ![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
11-30-2007, 04:09 PM
Post: #114
Thanks!
![]() Well, I showed you that the axle has different mounting points for the shocks: they are more or less a bit nearer to the center of the car. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
11-30-2007, 04:34 PM
Post: #115
i do have got a set of Tokico blues if you want!
Maybe a cheap inbetween solution for you problem ![]() You can testfit the rears then ![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
11-30-2007, 10:48 PM
Post: #116
Tempting...
![]() But I still think I'll go for the Konis: can get them quite cheaply. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
12-02-2007, 06:21 PM
Post: #117
Think I found the answer.
![]() Both the AE86 and TA60 have 48530 and 48540 as partnumber for the rear shock absorbers, only the TA60 has different mounting points. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
12-02-2007, 08:38 PM
Post: #118
are the whole partnumbers the same?
Because that first number says nothing more then: it's a shock ![]() Even my Starlet rear shocks do have those numbers, it's the number after the dash that counts! "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
12-02-2007, 10:06 PM
Post: #119
The Doctor Wrote:are the whole partnumbers the same?I thought they were the same, but I'll double check it then.. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
12-03-2007, 10:27 PM
Post: #120
Double checked: they are different in numbers.
![]() However... The front shocks differ in numbers as well, so we won't know till I've put them under the carina. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Banpei's two door panda Trueno from Japan | banpei | 6 | 740 |
01-06-2025 08:31 PM Last Post: Eircamae86 |
Family man's ae86 | fantapants | 90 | 65,613 |
11-12-2023 01:06 AM Last Post: fantapants |
My Carina TA60 | crxman | 17 | 19,844 |
01-09-2016 10:17 PM Last Post: nyberrg |
Project "Roku-ju" TA60 Carina | Motax | 24 | 38,820 |
03-05-2014 10:21 AM Last Post: Motax |
Carina TA60! | evanger | 7 | 15,412 |
10-23-2012 10:18 AM Last Post: Lightning |
