Best Suspension Setup/System
11-15-2007, 10:42 PM
Ive thought alot in how to get the best street/track/drifting setup on my car and cant think of anything.
What does Takumi have on his panda? Bilstein?
I Like the Greddy Coilies but is it the best thing to have?
Want something thats comfy but sporty as hell Evil
Im also going to change the control arms and sway bars.
Suggestions?
Alex/Sweden
Don´t Think About The Past,
Live In The Present And
Dream About Tomorrow
11-16-2007, 12:36 AM
Coil-Over conversion up front, Top-Mount Camber Adjusters, RCAs, Adj Shocks & Hard Springs @ the rear.
I would sugest http://www.technotoytuning.com for the camber plates, RCAs
11-16-2007, 05:19 PM
then what type of springs and shocks.
i didnt really get how to re done the old suspension parts.
11-16-2007, 05:29 PM
You would have to tell us what you want to use the car for...
[Image: AEU86 AE86 - Best Suspension Setup/System]
11-16-2007, 05:52 PM
DG-5 coilovers!Designed by Dori Kin.... Respect!
JapanPower
UoP Racing website
UoP Racing videos
11-16-2007, 05:56 PM
depned on your drivingskills as well....
11-16-2007, 06:04 PM
AshCampbell Wrote:depned on your drivingskills as well....
Yeah, suspension and suspension setup depends on really a lot of things...I suggest that you should decide for what use you want your car, "simulate" a setup in your mind (how you want the car to handle and respond), and then drive a couple of AE's with a similar setup to get an idea of the car's behavior.I suggest that you should go for an adjustable suspension, because you can experiment a lot on the setup.Especially on suspension, your personal touch and feeling is almost everything...
JapanPower
UoP Racing website
UoP Racing videos
11-16-2007, 07:33 PM
I think that Greddy would be pretty ok for what you need.
They are adjustable and can be set to "confy"mode.
If you're going to rally/off road I would suggest to get blistein shocks, spring rate is up to you.
And then some RCA or NCRCA and new bushings (Protane/TRD)
11-16-2007, 07:48 PM
Allexz Wrote:What does Takumi have on his panda? Bilstein?
Bilstein? on a japanese hachi? I doubt itBig Grin
If you watch the anime you'll know that he has Buntas special custom suspension.. so its likely custom rate springs with TRD shocks Bunta got from a friend at TRD specifically valved to its needs.. Offcourse after Project D got their hands on the Hachi it changed even more after that and I doubt it has any relation to anything you can just buy in the shops.
In the end though, its a cartoon! Takumi might aswell have bought his suspension on the moon, his suspension works as good as the cartoonist wants it to Smile
I'm not sure what they used for the live action movies though. Most likely anything sourced from sponsorsSmile
Back to giving serious answers.. I think the best advise has already been given, the best suspension depends on your objectives, what do you want to do... THere are some good direct swap kits out there so I would go for one of those if you're not the experimental type of person.
Also search around, there are several threads already discussing suspension to the fullest, loads of info already to be found.
11-16-2007, 10:48 PM
Allexz Wrote:Ive thought alot in how to get the best street/track/drifting setup
Alex/Sweden
Time for a reality check !!!! There is no such thing as a "comfy" drift
suspension. Stiff as a board suspension with no travel will ride like a
dray on the road, jump sideways in corners, and turn your milk to butter
by the time you get home from the supermarket Sad
Of course the car will handle like a go-kart on a smooth race track Smile
My advice... if you want an everyday driver that can handle the usual
bumps and uneven surfaces that most of us drive on evey day, go with
a set of "sports" lowering springs, Koni's, TRD rubber bushings and a
decent set of "performance" tires.
Cheers... jondee86
  Best quality Diffs gh0st 1 1,562 07-03-2022 07:49 PM
  Best Induction Kit / Set up chrisae86 20 16,187 06-10-2020 10:59 AM
Last Post: Lykowsky
  Stack display system, need help Jimmi The Kid 1 4,495 01-15-2017 10:52 PM
  Rim width. Which is best.... Dino86 5 7,031 01-07-2017 03:09 PM
Last Post: Dino86
  4 Link setup and Traction brackets Jezza_hr 5 10,602 07-21-2014 09:12 PM
