Best Suspension Setup/System
11-15-2007, 10:42 PM
Ive thought alot in how to get the best street/track/drifting setup on my car and cant think of anything.
What does Takumi have on his panda? Bilstein? I Like the Greddy Coilies but is it the best thing to have? Want something thats comfy but sporty as hell ![]() Im also going to change the control arms and sway bars. Suggestions? Alex/Sweden Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
11-16-2007, 12:36 AM
Coil-Over conversion up front, Top-Mount Camber Adjusters, RCAs, Adj Shocks & Hard Springs @ the rear.
I would sugest http://www.technotoytuning.com for the camber plates, RCAs An 86 is for Life, not just for Christmas |
11-16-2007, 05:19 PM
then what type of springs and shocks.
i didnt really get how to re done the old suspension parts. Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
11-16-2007, 05:29 PM
You would have to tell us what you want to use the car for...
Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
11-16-2007, 05:52 PM
DG-5 coilovers!Designed by Dori Kin....
![]() JapanPower UoP Racing website UoP Racing videos Racing, because football, basketball, tennis & golf only require ONE ball.... |
11-16-2007, 05:56 PM
depned on your drivingskills as well....
11-16-2007, 06:04 PM
AshCampbell Wrote:depned on your drivingskills as well.... Yeah, suspension and suspension setup depends on really a lot of things...I suggest that you should decide for what use you want your car, "simulate" a setup in your mind (how you want the car to handle and respond), and then drive a couple of AE's with a similar setup to get an idea of the car's behavior.I suggest that you should go for an adjustable suspension, because you can experiment a lot on the setup.Especially on suspension, your personal touch and feeling is almost everything... JapanPower UoP Racing website UoP Racing videos Racing, because football, basketball, tennis & golf only require ONE ball.... |
11-16-2007, 07:33 PM
I think that Greddy would be pretty ok for what you need.
They are adjustable and can be set to "confy"mode. If you're going to rally/off road I would suggest to get blistein shocks, spring rate is up to you. And then some RCA or NCRCA and new bushings (Protane/TRD) |
11-16-2007, 07:48 PM
Allexz Wrote:What does Takumi have on his panda? Bilstein?Bilstein? on a japanese hachi? I doubt it ![]() If you watch the anime you'll know that he has Buntas special custom suspension.. so its likely custom rate springs with TRD shocks Bunta got from a friend at TRD specifically valved to its needs.. Offcourse after Project D got their hands on the Hachi it changed even more after that and I doubt it has any relation to anything you can just buy in the shops. In the end though, its a cartoon! Takumi might aswell have bought his suspension on the moon, his suspension works as good as the cartoonist wants it to ![]() I'm not sure what they used for the live action movies though. Most likely anything sourced from sponsors ![]() Back to giving serious answers.. I think the best advise has already been given, the best suspension depends on your objectives, what do you want to do... THere are some good direct swap kits out there so I would go for one of those if you're not the experimental type of person. Also search around, there are several threads already discussing suspension to the fullest, loads of info already to be found. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
11-16-2007, 10:48 PM
Allexz Wrote:Ive thought alot in how to get the best street/track/drifting setup Time for a reality check !!!! There is no such thing as a "comfy" drift suspension. Stiff as a board suspension with no travel will ride like a dray on the road, jump sideways in corners, and turn your milk to butter by the time you get home from the supermarket ![]() Of course the car will handle like a go-kart on a smooth race track ![]() My advice... if you want an everyday driver that can handle the usual bumps and uneven surfaces that most of us drive on evey day, go with a set of "sports" lowering springs, Koni's, TRD rubber bushings and a decent set of "performance" tires. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
Best quality Diffs | gh0st | 1 | 1,511 |
07-03-2022 07:49 PM Last Post: banpei |
Best Induction Kit / Set up | chrisae86 | 20 | 15,701 |
06-10-2020 10:59 AM Last Post: Lykowsky |
Stack display system, need help | Jimmi The Kid | 1 | 4,410 |
01-15-2017 10:52 PM Last Post: Ivan141 |
Rim width. Which is best.... | Dino86 | 5 | 6,918 |
4 Link setup and Traction brackets | Jezza_hr | 5 | 10,464 |
07-21-2014 09:12 PM Last Post: Bean |
