Big brakes on my SE-86 at last.
09-13-2005, 09:42 AM
Long time no visit guys!
I'm being cheeky and have decided to call it an SE-86 from now on. ![]() The big brakes are on, and they seem to work well so far. ![]() The difference between the standard AE-86 disc and the big one. ![]() Test fit on the strut. ![]() 16" wheel, still plenty of room left. ![]() No backing plate, so I have to keep some temps in the brakes in puddles. ![]() Here's the mounting bracket, milled from a large chunk of alloy. Toyota RAV4 discs, 300m diameter 19mm thick & ventilated, Wilwood Dynalite four-spot cailpers, milled backing plate from a large chunk of alloy. So far well worth the effort. |
09-13-2005, 09:49 AM
Looks good Bill..nice to see you around again.
Did you have to redrill the RAV discs or do they have the same PCD on the disc itself? FABRICA MI DIEM, PVNC! |
09-13-2005, 09:51 AM
AFAIK all RAVs use 5-holes pattern.
09-13-2005, 09:54 AM
That's only on the hub, I believe the disc itself has a smaller PCD, as you can see in the pic of the two discs.
09-13-2005, 10:08 AM
Ivan141 Wrote:That's only on the hub, I believe the disc itself has a smaller PCD, as you can see in the pic of the two discs. But RAV uses front wheel drive also - so PCD is something like 5X114mm vs 4X85mm in RWD AE86. |
09-13-2005, 10:10 AM
Forgot about that...so it's most likely redrilled.
09-13-2005, 11:48 AM
Hey long time no see bill, hope live has been treating you good. It sure has from the loops of it, atleast hachi wise
![]() Damn those brakes look good! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-13-2005, 11:57 AM
Yep, they're re-drilled.
I tried to get them undrilled but couldn't do it. Now to make the rears larger .... ![]() |
09-13-2005, 01:10 PM
Billzilla Wrote:Now to make the rears larger .... Nissan Primera (G20, P10, P11) rear discs are almost straight fit. 257mm |
09-13-2005, 01:37 PM
jamiemirror Wrote:Billzilla Wrote:Now to make the rears larger .... Thanks, but that's not a lot bigger than standard is it? I was looking for something more like 300mm odd. |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,129 |
AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 614,215 |
AE86 N2 (big update) | 86Pilot | 110 | 138,821 |
09-06-2013 11:33 AM Last Post: Apsogos |
Brakes kill engine. | Super Snake | 3 | 4,775 |
04-27-2013 01:43 AM Last Post: Super Snake |
Brakes | ae86rebuild | 10 | 11,504 |
11-28-2009 01:38 AM Last Post: mc68 |
