Big brakes on my SE-86 at last.
09-13-2005, 09:42 AM
Long time no visit guys!
I'm being cheeky and have decided to call it an SE-86 from now on. Smile
The big brakes are on, and they seem to work well so far.
[Image: AEU86 AE86 - Big brakes on my SE-86 at last.]
The difference between the standard AE-86 disc and the big one.
Test fit on the strut.
16" wheel, still plenty of room left.
No backing plate, so I have to keep some temps in the brakes in puddles.
Here's the mounting bracket, milled from a large chunk of alloy.
Toyota RAV4 discs, 300m diameter 19mm thick & ventilated, Wilwood Dynalite four-spot cailpers, milled backing plate from a large chunk of alloy.
So far well worth the effort.
09-13-2005, 09:49 AM
Looks good Bill..nice to see you around again.
Did you have to redrill the RAV discs or do they have the same PCD on the disc itself?
09-13-2005, 09:51 AM
AFAIK all RAVs use 5-holes pattern.
09-13-2005, 09:54 AM
That's only on the hub, I believe the disc itself has a smaller PCD, as you can see in the pic of the two discs.
09-13-2005, 10:08 AM
Ivan141 Wrote:That's only on the hub, I believe the disc itself has a smaller PCD, as you can see in the pic of the two discs.
But RAV uses front wheel drive also - so PCD is something like 5X114mm vs 4X85mm in RWD AE86.
09-13-2005, 10:10 AM
Forgot about that...so it's most likely redrilled.
09-13-2005, 11:48 AM
Hey long time no see bill, hope live has been treating you good. It sure has from the loops of it, atleast hachi wiseSmile
Damn those brakes look good!
09-13-2005, 11:57 AM
Yep, they're re-drilled.
I tried to get them undrilled but couldn't do it.
Now to make the rears larger .... Smile
09-13-2005, 01:10 PM
Billzilla Wrote:Now to make the rears larger .... Smile
Nissan Primera (G20, P10, P11) rear discs are almost straight fit.
257mm
09-13-2005, 01:37 PM
257mm
Thanks, but that's not a lot bigger than standard is it?
I was looking for something more like 300mm odd.
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,129 09-09-2022 09:07 PM
Last Post: Vaptor
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 614,199 06-27-2017 12:21 PM
Last Post: DJexor
  AE86 N2 (big update) 86Pilot 110 138,818 09-06-2013 11:33 AM
Last Post: Apsogos
  Brakes kill engine. Super Snake 3 4,774 04-27-2013 01:43 AM
Last Post: Super Snake
  Brakes ae86rebuild 10 11,503 11-28-2009 01:38 AM
Last Post: mc68
