Blue top pistons
02-15-2008, 05:24 PM
Blue top pistons
Hi Guys,
Can anyone tell me where i can get a set of oversize std compression pistons?
Been let down by a supplier in the UK, and i have two engines sat at the engineers waiting to get bored out Crying
Any ideas?
Thanks
Jamey
02-15-2008, 06:01 PM
Blue top pistons
have you tryed in a toyota parts shop ?
02-15-2008, 07:36 PM
Blue top pistons
Yes! Try SYM from PASSRACING. He is also a member of this board (search username "sym").
For your kit check: http://passracing.com/
16v hi-comp 0.5 oversize pistons set & rings - 295 $ (us)
(hi-comp means 10:1 CR, found in euro bluetops with map)
He also charges very fair shipping and all the users have had good experience in dealing with him.
regards
02-16-2008, 12:10 PM
Blue top pistons
Thanks guys, the ones from Passracing look like hi-comp small port pistons which have 20mm wrist pins.
Looks like Toyota will be the only option, and everything is always expensive from Toyota Crying
Thanks
jamey
02-16-2008, 02:15 PM
Blue top pistons
See how much they are from Toyota, i have a full AE92 7rib bottom end for sale may work out cheaper!
02-16-2008, 10:15 PM
Blue top pistons
Thanks Rossi, its bit of a hybrid im building.
Ordered some from Toyota Today £240 for 4 pistons and rings 0.5mm OS
The engine is for my MR2 race car, its a 7 rib block for the rigidity and strength and blue top crank which has the 40mm jurnals so its slightly lighter and has less rotational mass.
Thats why i needed blue top pistons as they have the 18mm wrist pin.
Thanks
Jamey
02-17-2008, 05:14 PM
Blue top pistons
Cool, Toyota prices are mental tho!! Banging head
02-18-2008, 06:03 AM
Blue top pistons
I have the part number for the European and Singapore 10 to 1 O/S pistons designed to fit the 18mm pin.... I just ordered a set!
13103-16030 - The set of four are costing me $345.00(US dollars)
Dan -
02-28-2008, 03:51 PM
Blue top pistons
i bought the bigger sized pistons +0.50 from ebay.a seller give them to me for 80$ +shipping of course (4 pistons) they were the oem ones.u can check the ebay if u r intrested in them the oems.
02-28-2008, 05:43 PM
Blue top pistons
daywalker Wrote:i bought the bigger sized pistons +0.50 from ebay.a seller give them to me for 80$ +shipping of course (4 pistons) they were the oem ones.u can check the ebay if u r intrested in them the oems.
wow that cheap?? do you have a link?
[Image: AEU86 AE86 - Blue top pistons]
  Red top in the ae86 gh0st 25 11,647 08-08-2022 08:43 PM
Last Post: gh0st
  Replacing Top Windscreen Moulding chrisae86 2 2,190 06-18-2022 08:56 PM
Last Post: chrisae86
  82mm Stock compression Pistons apardal 4 2,998 11-24-2021 04:26 PM
Last Post: apardal
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,670 04-20-2018 09:14 AM
  Silver top low idle AlexFourTwenty 7 10,501 10-16-2017 10:22 PM
Last Post: AlexFourTwenty
