Blue top pistons
02-15-2008, 05:24 PM
Blue top pistons
Hi Guys,
Can anyone tell me where i can get a set of oversize std compression pistons? Been let down by a supplier in the UK, and i have two engines sat at the engineers waiting to get bored out Any ideas? Thanks Jamey |
02-15-2008, 06:01 PM
Blue top pistons
have you tryed in a toyota parts shop ?
02-15-2008, 07:36 PM
Blue top pistons
Yes! Try SYM from PASSRACING. He is also a member of this board (search username "sym").
For your kit check: http://passracing.com/ 16v hi-comp 0.5 oversize pistons set & rings - 295 $ (us) (hi-comp means 10:1 CR, found in euro bluetops with map) He also charges very fair shipping and all the users have had good experience in dealing with him. regards |
02-16-2008, 12:10 PM
Blue top pistons
Thanks guys, the ones from Passracing look like hi-comp small port pistons which have 20mm wrist pins.
Looks like Toyota will be the only option, and everything is always expensive from Toyota Thanks jamey |
02-16-2008, 02:15 PM
Blue top pistons
See how much they are from Toyota, i have a full AE92 7rib bottom end for sale may work out cheaper!
02-16-2008, 10:15 PM
Blue top pistons
Thanks Rossi, its bit of a hybrid im building.
Ordered some from Toyota Today £240 for 4 pistons and rings 0.5mm OS The engine is for my MR2 race car, its a 7 rib block for the rigidity and strength and blue top crank which has the 40mm jurnals so its slightly lighter and has less rotational mass. Thats why i needed blue top pistons as they have the 18mm wrist pin. Thanks Jamey |
02-17-2008, 05:14 PM
Blue top pistons
Cool, Toyota prices are mental tho!!
02-18-2008, 06:03 AM
Blue top pistons
I have the part number for the European and Singapore 10 to 1 O/S pistons designed to fit the 18mm pin.... I just ordered a set!
13103-16030 - The set of four are costing me $345.00(US dollars) Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-28-2008, 03:51 PM
Blue top pistons
i bought the bigger sized pistons +0.50 from ebay.a seller give them to me for 80$ +shipping of course (4 pistons) they were the oem ones.u can check the ebay if u r intrested in them the oems.
02-28-2008, 05:43 PM
Blue top pistons
daywalker Wrote:i bought the bigger sized pistons +0.50 from ebay.a seller give them to me for 80$ +shipping of course (4 pistons) they were the oem ones.u can check the ebay if u r intrested in them the oems. wow that cheap?? do you have a link? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
Red top in the ae86 | gh0st | 25 | 9,969 |
08-08-2022 08:43 PM Last Post: gh0st |
Replacing Top Windscreen Moulding | chrisae86 | 2 | 1,933 |
82mm Stock compression Pistons | apardal | 4 | 2,716 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 7,421 |
Silver top low idle | AlexFourTwenty | 7 | 10,048 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
