Bluetop Engine Rebuild multiple question Goal 150-160hp
04-13-2021, 08:10 PM
(04-12-2021 05:56 PM)oldeskewltoy Wrote:It seems that a ported head does make a large difference. It also clearly visible that the TVIS is working. There is quite a dent at 4500U/min.^^(04-11-2021 08:11 PM)Hanzo Wrote:(04-11-2021 05:28 AM)oldeskewltoy Wrote: Can you get to 150whp with a 4AGE, the answer is no problem, although the largeport intake manifold does become a challenge around 145-150whp. I'm making 145whp in my smallport* using Euro 10:1 pistons - but the head has been extensively worked - chambers now down to about 33cc, so compression is closer to 10.7:1 (* - smallport head and block, with a 40mm crank, rods, and 10:1 pistons) I'm using a mild cam Web camshafts 577 grind - equivalent to a 264 type, using 8.38mm lift. I've kept the smallport intake manifold (single T/B) My idea was that ported head is useful if i want to add ITBs later down the road. I only want to build that engine once ![]() |
04-15-2021, 09:55 PM
(This post was last modified: 04-15-2021 09:56 PM by Hanzo.)
(04-13-2021 01:35 PM)Project D Wrote:(04-10-2021 07:31 PM)Hanzo Wrote: [...]My goal is to get around 150hp. And maybe ITBs in the future (mostly for the sound Hello Project D, sorry for my late answer. And also thank you for the detailed reply. My answers 3.) good to know i will order this oil and water pump 5.) nice that there a still available. I will first try to find decent custom pistons like Dan recommended. 6.) That's a god tip. I wanted to change the injectors anyway, also I want to keep my build futureproof so i new ECU will be useful in the future. Can you recommend a ECU? I saw some youtubers like sushpants using ECUs from the brand LINK. 7.) That is a big difference, as you said. I want my Levin to run properly.^^ |
04-16-2021, 04:45 AM
(04-15-2021 09:55 PM)Hanzo Wrote: 5.) nice that there a still available. I will first try to find decent custom pistons like Dan recommended. Pistons: if you want them made "locally" you could look at Wossner. Otherwise, plenty of good options out there (Traum, CP, JE, etc...) Injectors: Go with something modern. having data is a plus. Not all injectors will fit. They have to be 11mm top feed, and they have to be "long". ECU: I have tuned a few in the last 10 years. If you are going to get it tuned by a professional: I would recommend to see what your tuner is familiar with. If you choose ECU from brand "X", but your tuner only know / tune brand "Y", it can be problematic... If you are going to tune it yourself: First, make sure you will be able to do it. If you never touched an engine management in your life, you probably won't (especially with ITB) If you've never done it but you want to, the 4AG with the stock intake is actually a good platform to start with. It's not crazy complicated as some would make it be, but it does require a bit of knowledge. So learn the basics first. Also, list what your needs would be. Nothing worse than buying something and realizing later on that it can't do what you want (lack of input/output, functionality, etc...) For a 4A-GE, if you want it to be future-proof you need at least: 2 temp input for air and coolant (but I would recommend at least 3) 2 to 4* analog input, one being dedicated to the throttle position (depending if it have onboard map sensor and wideband controler) 2 trigger input 1 digital input 1 CANBUS 4 ignitions output (only 1 if you want to keep the distributor) 4 injection output (no need for peak and hold if you plan to use modern injectors) 4 spare output (fuel pump relay, idle control, etc...) Link is good but can end up quite expensive. An AtomX would work, the futur-proof option would be the FuryX. (I personally only dealt with a G4+ Xtreme) Megasquirt. I have done plenty but I would advise AGAINST it. The appeal was the OEM ECU connector with the, now discontinued, DIYPNP version (not to be confused with the MSPNP, only for the US version of the AE86). Lack a tone of features, use the obsolete serial port for communication... MaxxECU. A solid option. the futur-proof option would be the Sport version. If your want to spend more on the engine management than the car itself, MoTeC, Emtron, Syvecs, Bosch Motorsport, Cosworth. All fabulous ECU but crazy expensive ! |
04-16-2021, 05:06 PM
(04-16-2021 04:45 AM)Project D Wrote: I would recommend to see what your tuner is familiar with. If you choose ECU from brand "X", but your tuner only know / tune brand "Y", it can be problematic... Can't stress this enough...... I often recommend shopping tuning shops, and once you find one you trust, go with something they are familiar tuning.... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-16-2021, 06:50 PM
Its strange how Megasquirt always seemed popular, but I've never encountered a single person who would recommend it.
04-16-2021, 07:25 PM
(04-16-2021 05:06 PM)oldeskewltoy Wrote:Sadly Tuning shop in Europe are not as common as in the USA.(04-16-2021 04:45 AM)Project D Wrote: I would recommend to see what your tuner is familiar with. If you choose ECU from brand "X", but your tuner only know / tune brand "Y", it can be problematic... I don't know about Germany, but here in France I could probably count real tuning shop (not generic chip tuning) on one hand... (04-16-2021 06:50 PM)Power_uP Wrote: Its strange how Megasquirt always seemed popular, but I've never encountered a single person who would recommend it.Back in the day, they used to be pretty cheap. (12 years ago a MS2 was less than €300 shipping to Europe included...) And, if they stayed cheap, as a learning tool they would be perfect. Actually, I WOULD recommend the "illegal clones" for anybody who want to experiment or get started. (Cost around $100/150 for a "MS2" based copy. I will not name them as they are pretty easy to find) |
04-19-2021, 10:08 PM
(This post was last modified: 04-19-2021 10:09 PM by Hanzo.)
(04-16-2021 04:45 AM)Project D Wrote:Quote:Pistons: if you want them made "locally" you could look at Wossner. Edit: I will figure out how to quote correctly in the future ![]() (04-16-2021 07:25 PM)Project D Wrote: Actually, I WOULD recommend the "illegal clones" for anybody who want to experiment or get started. This does sound like a good cost effective DIY solution. ![]() |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,738 |
Rear Differential rebuild | chenfon | 10 | 9,670 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,433 |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 10,403 |
Rear Caliper Rebuild | mad.matt | 16 | 17,174 |
01-19-2017 02:19 PM Last Post: Project D |
