Bodywork in 3 steps
11-22-2005, 05:55 PM
Bodywork in 3 steps
Looks cool! I thin I've seen this Trueno before, it looks sweet in this paint configuration... Anyway, I'd go red with black bumpers.
Ahhh, VTEC. All the lag, none of the turbo. It's like waiting for bad sex. |
11-22-2005, 07:51 PM
Bodywork in 3 steps
i agree with max_ae86 - too many pandas running loose.
11-29-2005, 11:47 AM
Bodywork in 3 steps
What do you think?
Those 5mm plates around rear struts should be strong enough Fun is not the straight line! |
11-29-2005, 12:29 PM
Bodywork in 3 steps
max_ae86 Wrote:What do you think? overkill steel will broke up in the weakest place anyway. continue work in that way and u will loose weight balance also
11-29-2005, 08:27 PM
Bodywork in 3 steps
hachi could always use some celulite in her but =) better weight distrib. only have to be careful to balance it left /right.
11-30-2005, 12:15 AM
Bodywork in 3 steps
Whoa... You're doing an excellent job.
Think it will hold.
12-01-2005, 10:10 AM
Bodywork in 3 steps
Well, I’m not as fast as Zax, regarding car rebuild but…
…no more rusty holes at the back! I hope 0,5 kg more at the back will make no difference. In stead of 3mm I put 5mm plates. It’s only 2mm thicker plate. Still, plenty job to go. Fun is not the straight line! |
12-01-2005, 10:59 AM
Bodywork in 3 steps
hMM,
In the rear tower ,there is two plates . There is regular 1mm plate,and a 2mm! So it i think that what you have made here is weaker then OE Regards, Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
12-01-2005, 11:07 AM
Bodywork in 3 steps
Denmark Wrote:hMM, But surely, better then a rusty hole, which I had before :wink: Fun is not the straight line! |
12-01-2005, 01:38 PM
Bodywork in 3 steps
max great effort! are you doing the work yourself?
| Ivan's coupe: bodywork is done | Ivan141 | 676 | 1,041,201 |
08-07-2024 08:46 AM Last Post: banpei |
![AEU86 AE86 - Bodywork in 3 steps [Image: AEU86 AE86 - Bodywork in 3 steps]](https://www.aeu86.org/sticker-banner-468.gif)
