[Bolt Torque] Bluetop head x Redtop block
09-18-2008, 03:07 PM
Currently overhaulin an engine for a client, thing is he already bought the car with a redtop block and bluetop head.
How much torque should in the head bolts? Kinda confused and dont want to mess this up.
Thank you for your time Thumbs up!
[Image: AEU86 AE86 - [Bolt Torque] Bluetop head x Redtop block]
09-18-2008, 05:33 PM
i guess it depends, do the torques differ from engine to engine?
There's a site out there with torque specs for engines from an AE92 (redtop i presume?)...
[s:a01cf5d775]
I'd say, depending on where the screw actually screws (or are both parts threaded?) go for a middle ground, or just torque it up to the bottom part spec (redtop block specs)[/s:a01cf5d775] (edit: robokill's suggestion sounds way more logical than mine)
then again, you might ruin the bluetop if the specs are way outta line.
The 4AGE manual, is that for a bluetop only? (it seems for AW's as well, they're sideways... but also bluetop?)
09-18-2008, 11:10 PM
I will bolt it like a regular Bluetop:
300kg , +90º, +90º
Thanks Pardal for the help Thumbs up!
cavey thank you for your help too
09-18-2008, 11:29 PM
As the head of the 4age is bigport always bolt it to those specs. The lower block is cast iron and won't crack while the head can!
  Question about 4AG 20v Engine Block CHACAMAN 1 1,813 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 10,250 04-19-2021 10:08 PM
Last Post: Hanzo
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,842 02-10-2020 06:39 PM
Last Post: Power_uP
  4AGE block differences explained (incl. some eyecandy) Bean 46 90,353 05-05-2019 04:03 AM
Last Post: Rocker100
  Cam Cap Bolt Snapped!! Alex170984 1 3,886 06-08-2018 01:17 PM
