Boost Gauge help with Pictures
10-17-2011, 04:43 PM
Post: #41
crap material... just to be clear, if you suck and blow into the white hose you get proper readings on the gauge? also disconnect the black hose and suck and blow though it while blocking with and without blocking the other end to see if air A goes through and B if it's sealing right - pending on the results, assuming you have good vacuum readings on the black hose to begin with the only ? will be the crush tube fitting or whatever fault you'll find.
10-17-2011, 05:34 PM
Post: #42
yeah its stupid as F***!
I have checked all of it just now...
When I remove the screw it seems like it doesn't build pressure towards 0.0
So when screw removed it gives me the -0.4 at idle
When the screw is back in it gives me 0.0 so that would be good...
But when I then punch in the gas I only get a little bit of movement so it then doesnt have enough pressure or air to put through...
I have 1 extra head without a screw... it seems to be a bit smaller - thats the only thing I can try.
Other than that I can try and link 1 hose to the boost meter with 1 diameter.
Those are the only 2 options I can think of right now.
-DWG- Drift Wolf Gaming
  EUDM gauge cluster banpei 22 4,252 08-15-2023 10:48 PM
  Detailed LHD engine bay pictures Bean 0 2,941 08-05-2018 04:09 PM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 7,517 12-06-2017 06:48 PM
  Analog gauge cluster tech Ivan141 33 41,796 01-31-2016 11:06 PM
  Original gauge with universal fuel sender Komba 4 6,232 01-05-2015 03:27 PM
Last Post: Komba
