Brake lights not working
03-07-2024, 11:24 AM
Hi guys Wave
So my Trueno's rear brake lights are not working all of a sudden when I hit the brake pedal. I looked a little bit online and found out that it could maybe be the brake light switch at the pedal itself. I also was going to check if the bulbs went out but both going out at the same time does not make sense.
What do you guys think? Do you guys have any images of how the pedal assembly are and where this switch is located?
Thanks in advance!
03-07-2024, 02:18 PM
Your brake light switch is located under the dash near the pivot bolt for the brake pedal.
03-07-2024, 03:42 PM
(03-07-2024 02:18 PM)Dave W Wrote:  Your brake light switch is located under the dash near the pivot bolt for the brake pedal.
Thanks for the help mate! I will check this out. Cheers Thumbs up!
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 8,910 12-19-2021 11:58 PM
Last Post: gh0st
  working out compression ratios kazi 2 3,848 07-16-2019 08:22 PM
Last Post: oldeskewltoy
  Dash lights not working. kazi 5 7,785 05-09-2017 12:31 PM
  Headlights - only high beam working Jezza_hr 3 7,660 01-10-2015 11:59 AM
Last Post: jondee86
  Carina TA62 / TA60 heater blower stopped working Bushido 9 11,875 11-14-2014 12:57 AM
Last Post: Bushido
User(s) browsing this thread:
