Brake master cylinder
05-31-2010, 05:33 PM
An old thread but a goodie.
May I just add, after bench bleeding the master cylinder, when you reinstall it, make sure the hard lines have something connected to the other end so your brake fluid doesn't drain out all over the floor........ Fortunately after staring dumbly wondering where the puddle was coming from, I had time to bung up the line with plastic plugs before the reservoir emptied.
In my defense, it was down to 6 degrees celsius here at midnight. Brrr.
  4AGE cylinder head plug removal Ivan141 5 1,997 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 13,870 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 7,156 07-26-2015 12:28 PM
Last Post: bozu
  torque setting head cylinder bolts izanagi 1 4,856 05-29-2015 01:23 AM
  Dimensions clutch master cylinder bozu 2 6,042 04-16-2015 07:11 AM
Last Post: bozu
