Dimensions clutch master cylinder
04-15-2015, 07:39 AM
Gents,
Just chasing some dimensions on the AE86 clutch master cylinder.
Currently not able to measure these myself on the car hence this topic.
Looking for:
- Outside diameter of housing;
- Size of studs;
- Center to center of studs (bolt pattern);
- Length behind face of mounting flange;
- Length in front of face of mounting flange;
- Stroke;
- Thread size push rod;
- Length of push rod.
To put all the information in this topic for future reference the bore is 0.625"
Regards,
Bozu
AE86 Levin
04-15-2015, 06:39 PM
- Outside diameter of housing:
~26mm outside, 30mm for the hole on the firewall
- Size of studs:
1 stud 1 bolt, both in M8
- Center to center of studs (bolt pattern):
72mm @ 45° asymmetrical (40/32 from the center)
- Length behind face of mounting flange:
~45mm
- Length in front of face of mounting flange:
~80mm (including the flange)
- Stroke:
~30mm
- Thread size push rod:
M8
- Length of push rod:
~50mm
04-16-2015, 07:11 AM
You da man! Thank you very much!
AE86 Levin
  4AGE cylinder head plug removal Ivan141 5 3,055 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 16,043 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 8,106 07-26-2015 12:28 PM
Last Post: bozu
  Quick question - Brake Pad Dimensions Lt86 2 5,880 06-07-2015 12:08 AM
Last Post: jondee86
  torque setting head cylinder bolts izanagi 1 5,452 05-29-2015 01:23 AM
