Dimensions clutch master cylinder
04-15-2015, 07:39 AM
Gents,
Just chasing some dimensions on the AE86 clutch master cylinder. Currently not able to measure these myself on the car hence this topic. Looking for: - Outside diameter of housing; - Size of studs; - Center to center of studs (bolt pattern); - Length behind face of mounting flange; - Length in front of face of mounting flange; - Stroke; - Thread size push rod; - Length of push rod. To put all the information in this topic for future reference the bore is 0.625" Regards, Bozu AE86 Levin |
04-15-2015, 06:39 PM
- Outside diameter of housing:
~26mm outside, 30mm for the hole on the firewall - Size of studs: 1 stud 1 bolt, both in M8 - Center to center of studs (bolt pattern): 72mm @ 45° asymmetrical (40/32 from the center) - Length behind face of mounting flange: ~45mm - Length in front of face of mounting flange: ~80mm (including the flange) - Stroke: ~30mm - Thread size push rod: M8 - Length of push rod: ~50mm |
04-16-2015, 07:11 AM
You da man! Thank you very much!
AE86 Levin |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,363 |
Brake advice - master cylinder | mannix20vt | 12 | 14,755 |
Correct connection brake master cylinder? | bozu | 5 | 7,597 |
Quick question - Brake Pad Dimensions | Lt86 | 2 | 5,527 |
06-07-2015 12:08 AM Last Post: jondee86 |
torque setting head cylinder bolts | izanagi | 1 | 5,100 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
