Quick question - Brake Pad Dimensions
06-01-2015, 10:47 PM
Hi guys,
Quick question, I need to know the dimensions of stock AE86 brake pads. 1986 Europe AE86 levin hatchback if that would matter... ![]() 3 options: Brembo, TRW and NK. Alle pretty cheap Around $30-40 dollars without discount for these BUT TRW has different dimensions than Brembo and NK. Does anyone know what fits 100%? Dikte = thickness Breedte = width hoogte = height. ![]() ![]() ![]() Thanks in advance! |
06-02-2015, 11:54 AM
The TRW sizes are correct.. both others are 10mm too wide if you ask me.
About to swap the greenstuffs on my daily for some cheaper TRW pads myself.. curious to see how they stack up. FABRICA MI DIEM, PVNC! |
06-07-2015, 12:08 AM
This is what I had on file...
![]() Cheers... jondee86 |
4age hitting gas too quick means engine stalls - what is the issue? | Ryo | 20 | 33,150 |
06-27-2018 11:15 PM Last Post: Ryo |
Quaife quick rack | totta Crolla | 19 | 23,085 |
03-03-2018 03:32 PM Last Post: Deuce Cam |
DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 20,184 |
Dimensions clutch master cylinder | bozu | 2 | 6,735 |
04-16-2015 07:11 AM Last Post: bozu |
Advan A3A need quick help | Ryo | 49 | 65,019 |
09-23-2014 04:34 PM Last Post: conal g |
