Quick question - Brake Pad Dimensions
06-01-2015, 10:47 PM
Hi guys,
Quick question, I need to know the dimensions of stock AE86 brake pads.
1986 Europe AE86 levin hatchback if that would matter... Smile. At the moment I can't access my car else I would measure myself.
3 options:
Brembo, TRW and NK. Alle pretty cheap Around $30-40 dollars without discount for these BUT TRW has different dimensions than Brembo and NK. Does anyone know what fits 100%?
Dikte = thickness
Breedte = width
hoogte = height.
[Image: AEU86 AE86 - Quick question - Brake Pad Dimensions]
Thanks in advance!
06-02-2015, 11:54 AM
The TRW sizes are correct.. both others are 10mm too wide if you ask me.
About to swap the greenstuffs on my daily for some cheaper TRW pads myself..
curious to see how they stack up.
06-07-2015, 12:08 AM
This is what I had on file...
Cheers... jondee86
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 30,544 06-27-2018 11:15 PM
Last Post: Ryo
  Quaife quick rack totta Crolla 19 21,670 03-03-2018 03:32 PM
Last Post: Deuce Cam
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 18,906 12-21-2016 10:28 PM
Last Post: ditn
  Dimensions clutch master cylinder bozu 2 6,331 04-16-2015 07:11 AM
Last Post: bozu
  Advan A3A need quick help Ryo 49 61,301 09-23-2014 04:34 PM
Last Post: conal g
