Bushings!:)
06-06-2005, 02:45 PM
Post: #31
Bushings!:)
Widar: problem with rear swaybar!
06-06-2005, 09:50 PM
Post: #32
Bushings!:)
Widar Wrote:KristianAE86, that is for the front. As far as i remember there are two types of front swaybars, one 21mm and one 22mm therefor double sets. What you want is this one;
well those pictured by you are just for the end-fittings for the swaybar.
i found the ones i was missing just now.
So when i´m done wioth the bushings.. I will have two left - the ones i pictured. ?
correct ?
K
06-06-2005, 10:34 PM
Post: #33
Bushings!:)
err.....mine came with those....and a set of smaller ones
i supose those are for larger sway bars, like trd´s....
didnt your kit came with a extra set of those, with a smaller hole? Huh
06-07-2005, 12:22 AM
Post: #34
Bushings!:)
correct ?
K
Um.. I stand corrected. Remember that i havent fitted my bushings yet Wink
Yes, you should get a set left after all mounted.
[Image: AEU86 AE86 - Bushings!:)]
06-07-2005, 10:45 AM
Post: #35
Bushings!:)
Kristian, I have fitted mine and I have the same set left. I can't figure out where they're supposed to go. I've changed all the bushings and double checked everything, but I'm still left with that same set.
Perhaps we got an extra set?
06-07-2005, 10:55 AM
Post: #36
Bushings!:)
Dorito86 Wrote:Kristian, I have fitted mine and I have the same set left. I can't figure out where they're supposed to go. I've changed all the bushings and double checked everything, but I'm still left with that same set.
Hurray!
The bushings man (can't recall the company lol) didn't want us to not be able to put bushings all way around, therefor double sets! Thumbs up!
06-07-2005, 05:44 PM
Post: #37
Bushings!:)
This set that Widar pictured..
the bushings on the left & right - i cannot get those botls loose at all.
any ideas ?
06-07-2005, 09:09 PM
Post: #38
Bushings!:)
KristianAE86 Wrote:This set that Widar pictured..
any ideas ?
Cut and get new ones? Dumb question
06-08-2005, 12:05 AM
Post: #39
Bushings!:)
any ideas ?
got them loose --- i found the 17mm bolts on the sides that were hidden beneath all the rustcoating...
Now theyre off
06-08-2005, 12:47 AM
Post: #40
Bushings!:)
any ideas ?
Now theyre off
Haha! Thumbs up!
  Poly vs OEM bushings Jezza_hr 5 7,537 05-14-2014 11:28 PM
Last Post: Jezza_hr
  Steering Rack bushings filh 4 5,926 03-12-2010 10:45 PM
Last Post: filh
  Drivers review Prothane Bushings Michel 11 16,870 04-13-2008 05:57 PM
Last Post: Mux213
  Witch one to buy?(Bushings) zounds 3 4,879 11-23-2006 12:03 AM
Last Post: delange
  Bushings question. CircuitFreak 18 16,736 06-20-2006 03:02 PM
