Bushings!:)
06-06-2005, 02:45 PM
Post: #31
Bushings!:)
Widar: problem with rear swaybar!
06-06-2005, 09:50 PM
Post: #32
Bushings!:)
Widar Wrote:KristianAE86, that is for the front. As far as i remember there are two types of front swaybars, one 21mm and one 22mm therefor double sets. What you want is this one; well those pictured by you are just for the end-fittings for the swaybar. i found the ones i was missing just now. So when i´m done wioth the bushings.. I will have two left - the ones i pictured. ? correct ? K I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
06-06-2005, 10:34 PM
Post: #33
Bushings!:)
err.....mine came with those....and a set of smaller ones
i supose those are for larger sway bars, like trd´s.... didnt your kit came with a extra set of those, with a smaller hole? |
06-07-2005, 12:22 AM
Post: #34
Bushings!:)
KristianAE86 Wrote:Um.. I stand corrected. Remember that i havent fitted my bushings yetWidar Wrote:KristianAE86, that is for the front. As far as i remember there are two types of front swaybars, one 21mm and one 22mm therefor double sets. What you want is this one; Yes, you should get a set left after all mounted. |
06-07-2005, 10:45 AM
Post: #35
Bushings!:)
Kristian, I have fitted mine and I have the same set left. I can't figure out where they're supposed to go. I've changed all the bushings and double checked everything, but I'm still left with that same set.
Perhaps we got an extra set? |
06-07-2005, 10:55 AM
Post: #36
Bushings!:)
Dorito86 Wrote:Kristian, I have fitted mine and I have the same set left. I can't figure out where they're supposed to go. I've changed all the bushings and double checked everything, but I'm still left with that same set. Widar Wrote:KristianAE86, that is for the front. As far as i remember there are two types of front swaybars, one 21mm and one 22mm therefor double sets. What you want is this one; The bushings man (can't recall the company lol) didn't want us to not be able to put bushings all way around, therefor double sets! |
06-07-2005, 05:44 PM
Post: #37
Bushings!:)
Widar Wrote:KristianAE86, that is for the front. As far as i remember there are two types of front swaybars, one 21mm and one 22mm therefor double sets. What you want is this one; This set that Widar pictured.. the bushings on the left & right - i cannot get those botls loose at all. any ideas ? I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
06-07-2005, 09:09 PM
Post: #38
Bushings!:)
KristianAE86 Wrote:This set that Widar pictured..Cut and get new ones? |
06-08-2005, 12:05 AM
Post: #39
Bushings!:)
Widar Wrote:KristianAE86 Wrote:This set that Widar pictured..Cut and get new ones? got them loose --- i found the 17mm bolts on the sides that were hidden beneath all the rustcoating... Now theyre off I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
06-08-2005, 12:47 AM
Post: #40
Bushings!:)
KristianAE86 Wrote:Haha!Widar Wrote:KristianAE86 Wrote:This set that Widar pictured..Cut and get new ones? |
Poly vs OEM bushings | Jezza_hr | 5 | 7,527 |
05-14-2014 11:28 PM Last Post: Jezza_hr |
Steering Rack bushings | filh | 4 | 5,923 |
03-12-2010 10:45 PM Last Post: filh |
Drivers review Prothane Bushings | Michel | 11 | 16,867 |
04-13-2008 05:57 PM Last Post: Mux213 |
Witch one to buy?(Bushings) | zounds | 3 | 4,879 |
11-23-2006 12:03 AM Last Post: delange |
Bushings question. | CircuitFreak | 18 | 16,705 |
06-20-2006 03:02 PM Last Post: Ivan141 |
