Cam Cap Bolt Snapped!!
06-08-2018, 12:50 PM
Hi all,
I was checking my valve clearance and upon removing one of the cam cap bolts, it snapped!!
I have about 5mm sticking out of the head and mole grips are not working- they are squashing any meat left of the stud.
My first place was to put a nut on the end half way down, fill the hole with super steel and then attempt to unwind it. If that fails i'll have to try and drill it out.
Does anyone else have any ideas?
Cheers
06-08-2018, 01:17 PM
Put a nut on it and weld it to the remains of the bolt. The heat cycle will help loosen the bolt.
  HKS 260 8.0 Cam Card d3nso 5 7,243 02-14-2018 08:29 PM
  crank 6 bolt flywheel DJexor 5 8,364 12-05-2016 08:21 AM
Last Post: d3nso
  brake booster difference zenki(2 bolt)/kouki 4 bolt v ditn 1 4,506 03-22-2016 09:43 PM
Last Post: ditn
  4A-GE 20V ITB bolt patterns kjb 7 12,463 02-27-2016 01:23 PM
Last Post: kjb
  Camshaft sprocket bolt size? harkes 1 4,766 07-03-2015 12:41 PM
Last Post: Dave W
