Cams for a stock 4age 16v
10-09-2008, 08:54 PM
Post: #51
Ivan141 Wrote:Wasnt there someone who mentioned that 3SGE lifters will also work on a 4age (under-bucket shims!)? yup but never seen it in an engine. Besides I don't have spare 3sge lifters Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
10-09-2008, 10:19 PM
Post: #52
tolisspi Wrote:My engine is 4age bigport tvis Still very interessted in the answer. What will a 272° 10.3mm Toda Setup produce? And how will the lift afect idle, and rpm range (8mm, 9.5mm, 10.3mm...) |
10-09-2008, 10:54 PM
Post: #53
I dont know mate yet. I have to repair the head first and ll see.
Also i order shims kit of TODA and ARP head stud **COROLLA EE80 - 4AGE 124HP** |
10-27-2008, 09:47 AM
Post: #54
I'd like to dig out that thread again, because of some personal interesses:
Where is the peak HP for following cams, without dialing with a adjustable pully. 256 264 272 288 |
10-27-2008, 11:41 AM
Post: #55
MartinS, it is impossible for anyone here to answer that question. Camshafts are not only specificated in duration. Lift is very important.
288 duration camshafts at 7.9mm lift (Toda) are able to produce peak horsepower at 7500rpm. And this number will vary accordingly to the rest of the engine setup. Robokill, I'm running 7M-GE 300cc's injectors and I get 80% injector opening with my setup. 304 7.5mm TRD camshafts on ITB's. I've just bought a pair of Kent camshafts with 298 duration and 9.4mm of lift and I'm almost sure I'll have to raise fuel pressure to keep injector opening rates low. You can have 250cc's injectors, for sure, but you have to raise fuel pressure a lot! Best regards |
10-27-2008, 11:49 AM
Post: #56
Yeah, I understand but a aprox. idea where to aim for?
I'm quite fancy to see a dyno on 272 10.3mm Toda. Where would you guess Peak HP? 8000, 8500? |
10-27-2008, 11:58 AM
Post: #57
Yes, it will be around that range I think!
10-27-2008, 12:55 PM
Post: #58
that depends on loads of things .... with stock intake manifold and exhaust i don't think peak power will be that high
10-27-2008, 11:19 PM
Post: #59
Here is mine on the dyno made 133@ the wheels7650 rpm.
4AGE,HKS 264 cams,TVIS removed Kakimoto exhaust http://uk.youtube.com/watch?v=krMns5rOTJ0 |
10-28-2008, 08:11 AM
Post: #60
But i think with adjust cam gears that you can adjustable the in which rev get the power, medium or high revs, isnt it?
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,352 |
82mm Stock compression Pistons | apardal | 4 | 2,739 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 20,440 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 20,936 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,162 |
