Carb'd 4AGE on Hyperpak ignition no spark problem
01-05-2011, 01:33 AM
Sounds just like my ignition problem after my recent engine rebuild!
I´m not running fancy carbs with aftermarket parts, but it just turned out the the ignition coil somehow lost it´s earth, wireing and coil stayed untouched all the time!!! I searched weeks, changed coil/ distributors/ leads plugs, read diagnois codes. Nothing. Got a tip, to run a direkt wire from neg. Terminal to housing and got sparks again! Worth a try I guess??? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
Messages In This Thread |
Carb'd 4AGE on Hyperpak ignition no spark problem - 4AGE FORD - 01-03-2011, 11:03 PM
[] - fax0815 - 01-05-2011 01:33 AM
Ignition switch plug and wires | Blaze0010 | 3 | 221 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,338 |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 15,129 |
Carb question please help | MIGGZFSU | 3 | 4,619 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
extracted freedom ecu 16v ignition map | ditn | 7 | 8,793 |
