Carb'd 4AGE on Hyperpak ignition no spark problem
01-03-2011, 11:03 PM
Hi guys i have a bigport 4AGE engine from a AW11 MR2 on carbs with a Hyperpak ignition control unit to run the stock distributor.
I am unable to get the engine to start due to no spark, well i say no spark i actually get one weak spark at the very first crank of the engine and then nothing at all when i continue to crank the engine. I dont always get the spark at the first crank of the engine either, its a bit intermittent. I have double checked the wiring against the diagram that came with the kit and the ignition coil is brand new. I'm at a loss with what is wrong with it, my only thoughts are that the distributor is causing my problems or the hyperpak unit itself. ![]() Are the distributors known to give ignition faults or are they fairly reliable? Any help with this would be most appreciated. ![]() ![]() |
01-04-2011, 03:00 PM
Distributors are fairly reliable I would say. Sounds like it's not getting the right signal, or the signal isnt clean enough.
01-04-2011, 11:29 PM
Thanks for reply.
![]() When you say it sounds like its not getting the right signal or the signal isnt clean enough what exactly do you mean? Thanks ![]() |
01-05-2011, 01:33 AM
Sounds just like my ignition problem after my recent engine rebuild!
![]() I´m not running fancy carbs with aftermarket parts, but it just turned out the the ignition coil somehow lost it´s earth, wireing and coil stayed untouched all the time!!! I searched weeks, changed coil/ distributors/ leads plugs, read diagnois codes. Nothing. Got a tip, to run a direkt wire from neg. Terminal to housing and got sparks again! Worth a try I guess??? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-06-2011, 12:03 AM
Here is a scan of the wiring diagram for the hyperpak, i have wired everything as per diagram/instructions.
![]() The yellow wire from the hyperpak on the diagram is not visable but it connects to the (-) side of the ignition coil. ![]() |
01-19-2011, 09:03 PM
Well i've had the Hyperpak unit tested and as i suspected its dud.
![]() At least i know what my problem is now. |
01-19-2011, 10:24 PM
4AGE FORD Wrote:Well i've had the Hyperpak unit tested and as i suspected its dud. i was looking at getting one of those myself later in the year when i install carbs and cams. any word back from the manufacturer if theyll do a trade on another unit for you? |
01-19-2011, 11:47 PM
chaycore Wrote:4AGE FORD Wrote:Well i've had the Hyperpak unit tested and as i suspected its dud. No I've not had a single reply to any of the emails I've sent, I'm not really that suprised after the hassel i had getting the thing in the first place. ![]() I've given up on it now and decided to go down the mappable Megajolt/Edis trigger wheel route. ![]() |
01-20-2011, 01:05 AM
you wanna get rid of the duff unit? i may know someone who can look into fixing it.
01-21-2011, 11:10 PM
Someone else already has it to do just that/copy it. Thats if they can get through all the epoxy resin that it is covered in!
Ignition switch plug and wires | Blaze0010 | 3 | 606 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,139 |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 16,095 |
Carb question please help | MIGGZFSU | 3 | 4,907 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,350 |
User(s) browsing this thread:
