Carina drivers! - Coilovers for a TA60/62
05-08-2017, 10:45 AM
Hey!
What coilovers are you running on your cars? What can be modded to fit? What fits? My struts have a 90mm spacing between the bolts connecting it to the knuckle and each bolt in the strut tower is 107mm apart I have heard s13 coils might work with some mods. I assume that I would need to buy a set of coils that dont come with hubs and weld the bottom of my own strut to the coil. Tell me what you know, thanks! |
05-24-2017, 10:28 AM
Hi,
I have an TA60 Celica, it is the same platform as the Carina. I know the following: FRONT S13 camber plates work with minor adjustments of the bolts. MA6x Supra camber plates don't work. For the bottom you should get a rolling center adjuster. The only ones I know of are manufactured by T3. AE86 ones DON'T work. I think the easiest is to get 2 sleeves from https://www.rallydesign.co.uk , cut and weld your strut, get short stroke shocks, here is a complete guide http://club4ag.com/faq_and_tech_pages/Sh...ersion.htm REAR You can use AE86 coilovers, they bolt up if I remember correctly. I personally decided to go on the cheap way for the rear and just got a pair of yellow Koni shocks (AE86 ones) and stiffer springs (Nissan 350Z early models work fine, and they are 6.1 kg/mm, got them for like 30 euros on ebay for a pair). |
06-05-2017, 10:03 AM
(05-24-2017 10:28 AM)domi007 Wrote: Hi,MA60 roll center adjusters fit my carina. Currently run those. I was thinking of ordering custom BC Racing ae86 coils with s13 camber plates and then get ae86 knuckles to bolt them in the bottom. I dont know if the knuckles will fit yet though. There may be some spare ones in my garage but i got some sudden engine issues to sort out first ![]() Skickat från min ONEPLUS A3003 via Tapatalk |
Carina TA63 GT-TR - Suspension?? | danny 86 | 11 | 8,877 |
01-30-2021 03:39 PM Last Post: danny 86 |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,895 |
05-30-2017 10:50 AM Last Post: bozu |
D2 Coilovers any good? | heshan | 18 | 27,092 |
04-04-2017 02:40 AM Last Post: hachirokkos |
TA60/TA62 Carina; what fits? | nyberrg | 10 | 16,464 |
10-12-2016 12:57 PM Last Post: The Doctor |
Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 12,402 |
09-05-2016 12:28 PM Last Post: mad.matt |
