(Catching up) OST-080 (and OST-074):Dan Dabbles in Dubs
06-13-2022, 05:33 PM
I have a friend with a few Porsche 924s.....
OST-074: 3 down........ I found in both Porsche heads the bowls to already be too large for making substantial improvements - short radius work and simple seat/bowl clean-up
[Image: AEU86 AE86 - (Catching up) OST-080 (and ...es in Dubs]
The big thing with both of these heads - guide wear
OST-080: With this head the client went big valves... and the new seats broke the head Huh Sad
A replacement was found - $$
Even with the bigger valves - there still wasn't a lot of material removed do to the oversize bowl/seat diameter.
A finished chamber showing the big valves, and the multi-angle valve job.
On the exhaust side there was some room in the port walls....
On this one the client converted from factory EFI, to something a bit less fuel efficient.....
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,491 10-28-2022 08:23 AM
Last Post: decryphe
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,253 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,091 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,662 06-28-2022 09:17 PM
  (Catching up...) OST-081: STOP... do not touch if you don't know wtf you are doing oldeskewltoy 0 1,580 06-17-2022 09:07 PM
