(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams
08-31-2022, 09:38 PM
RE: (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams
working the oil drain is no small feat.... even when installed correctly, they can be fragile.
Adding it starts with courage (about to drill and could possibly ruin the head), and a wide selection of drill bits, along with burrs to get the hole open in the right place. Then the tap is used to further open the hole and add threads.
This was a gif from about 7 years back....
[Image: AEU86 AE86 - RE: (Catching up...)  OST-0... lift cams]
The problem with this one (above) is it can interfere with coolant plumbing at the back of the head. As my work later progresses, I move the fitting for better fitment.
Using essentially the same tools (various drill bits, and burrs) to properly open the hole to accept the 3/8" NPT tap.
briefly speaking to its fragility.... and placement
I offer 3 types of fittings....
Dan -
Messages In This Thread
RE: (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams - oldeskewltoy - 08-31-2022 09:38 PM
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 2,295 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 4,234 09-18-2022 02:19 AM
Last Post: oldeskewltoy
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 1,918 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 1,519 06-28-2022 09:17 PM
  (Catching up...) OST-081: STOP... do not touch if you don't know wtf you are doing oldeskewltoy 0 1,461 06-17-2022 09:07 PM
