Clutch Master Cylinder..how to remove?
10-09-2006, 12:03 PM
yes, it is possible...
I rebuilt mine a few days ago, and I was actually going to write a post that i wanted to sue TOYOTA for making it so difficult ;-)
To remove the the clutch master cylinder by making it slide between the stud and the the brake booster, you have to push the stud in a bit.
You can go inside the car, and put something like a big screwdriver inbetween the firewall and the clutch pedal assembly, which will bend it back a bit, pulling the stud inside a bit, which will give you enough room between the stud and the brake booster to pull out the clutch master cylinder....
On one of my hachis I have actually filed the stud down a little bit, which
makes changing the clutch master cylinder easy...
[Image: AEU86 AE86 -  ]
Koukis - Red, Silver/Gray,
Messages In This Thread
[] - mrgud - 10-09-2006, 12:00 PM
[] - dAYTONA - 10-09-2006 12:03 PM
[] - Sanity Clause - 11-01-2006, 10:52 PM
[] - Ivan141 - 11-01-2006, 10:54 PM
  4AGE cylinder head plug removal Ivan141 5 2,210 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 14,461 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 7,445 07-26-2015 12:28 PM
Last Post: bozu
  torque setting head cylinder bolts izanagi 1 5,015 05-29-2015 01:23 AM
  Dimensions clutch master cylinder bozu 2 6,206 04-16-2015 07:11 AM
Last Post: bozu
