Clutch and brake cylinders
10-13-2017, 06:44 PM
Hey guys, if this has been covered on here I'll apologize now already did not find anything.
1: now some of you know this is a ae85 and it's auto and RHD
2: I'm converting to manual, have a t50 box and the ae86 peddles already
No toyota dealers here stock the clutch master cylinder, what replacement can I use from other vehicles?
3: will my brake cylinder be able to handle rx7 fd front calipers and ae101 rear calipers, if not what are my options
Obviously I don't want the most expensive stuff please lol
Thanks in advance guys
Sent from my F3111 using Tapatalk
Signature removed due to large photobucket message
10-13-2017, 08:04 PM
Don't know the exact year and trim but Google for hilux BMC and I think also some from Subarus should work. Obviously some will fit with less modifications than others
10-14-2017, 07:41 PM
(10-13-2017 08:04 PM)Bean Wrote:  Don't know the exact year and trim but Google for hilux BMC and I think also some from Subarus should work. Obviously some will fit with less modifications than others
awesome will have a look now thanks bud
10-14-2017, 07:44 PM
I read on another forum recently that the Kouki BMC is adequate for the FD Calipers by them self but if not, the Pajero BMC for the 2 Bolt booster is a good upgrade.
Might be worth buying a used CMC and rebuilding it.
10-14-2017, 07:52 PM
(10-14-2017 07:44 PM)mad.matt Wrote:  I read on another forum recently that the Kouki BMC is adequate for the FD Calipers by them self but if not, the Pajero BMC for the 2 Bolt booster is a good upgrade.
thanks will have a look now for the BMC just concerned if the AE85 was not Different to the AE86 cant see anything
Was thinking of just getting a used CMC and like you said rebuilding here
  PWR light issue and no brake fluid after winter storage magpie 10 3,217 05-25-2023 08:09 AM
  Where to buy new master and slave clutch cylinders? krullibull 6 7,753 06-27-2013 07:57 PM
Last Post: krullibull
  max brake disc thickness ae86 caliper+heel and toe question ditn 26 27,706 10-02-2012 05:00 PM
Last Post: ditn
  AE92 brake booster and master cylinder into AE86 bel_air 8 12,696 08-02-2012 10:51 AM
Last Post: bel_air
  Brake booster and ITB's on 16v harkes 17 29,961 08-01-2012 03:59 PM
