Clutch pedal problem
07-25-2013, 12:36 AM
I have another issue with my 83 levin. When I first go to press my clutch the pedal travels about half way before it grabs anything and the biting point is very low, if I let off and press again the pedal grabs alot sooner so my biting point is higher than the first press.
If I rest my foot on the pedal to take up the slack the biting point of the clutch will be half way all the time which is good. If i let the pedal come all the way back out to its resting position and press the pedal it will travel about half way again and the biting point is at the very bottom. Again if I pump it once the biting point will be back to half way.
It has had a new slave cylinder and clutch at one point, only thing left to do is change the master cylinder but obviously I just wanted some advice before I go spending
Thanks
Messages In This Thread
Clutch pedal problem - andee17 - 07-25-2013 12:36 AM
[] - Ivan141 - 07-25-2013, 09:33 AM
[] - jondee86 - 07-25-2013, 11:57 AM
  clutch pedal return spring Eifelaner 2 7,171 09-06-2013 10:21 AM
Last Post: Apsogos
  Clutch problem Rascal21 4 5,536 05-31-2013 06:00 PM
Last Post: Alex170984
  4agZe problem solved - 99% IC problem Okami 41 35,806 07-12-2012 04:49 PM
Last Post: Okami
  AC problem? Idle problem? KD2229 3 4,770 08-19-2009 02:08 AM
Last Post: KD2229
  Clutch Master Cylinder and Clutch Slave Cylinder fitment? christsang7 2 5,073 07-01-2009 07:48 AM
Last Post: jondee86
