Coilovers etc...
11-02-2004, 11:28 AM
Coilovers etc...
Hey Guys,
Okay I finally found out what sorta springs I have. Standard APEX ones. The guy who had the car before me can't remember the spring rates but I believe they only came around 3kg.
So I'm thinking of going different springs to fix my role problem. Now Ivan suggested I'd take a look at the coil overs from Paradise Racing. Zax has them aswell I think. They are for the front suspention only so I need to figure out what to do at the rear.
Anybody got some advise on their experience with this setup?
11-02-2004, 01:52 PM
Coilovers etc...
Try thicker swaybars first. It might wash the problem away.
11-02-2004, 03:00 PM
Coilovers etc...
Dont use thicker swaybars...you have a lack of springrate at the moment. Buy the swaybars if 6kg/mm springs arent strong enough.
[btw, I fiddled with the topic title a bit..it had some spelling errors Dumb question ]
11-02-2004, 04:34 PM
Coilovers etc...
Did you buy new bushings for your swaybar? That might do the trick Smile I kind of have the same problem and I use TRD Competetion springs and shocks Dumb question
[Image: AEU86 AE86 - Coilovers etc...]
11-02-2004, 04:48 PM
Coilovers etc...
Bought yes
installed noSmile
Coilovers etc...
Well..the prothane bushings have arrived so those wont take long to get under his car..
11-02-2004, 06:17 PM
Coilovers etc...
mux213 Wrote:Hey Guys,
Get some TRD spring for the rear. You can get them for either short stroke dampers (Thats what I use) or lowerd height. You should be able to order them in different spring rates. Check here:
http://www.trdparts.jp/list_ae86.html
You can order them from TTE in Germany, they supplied me with most of my TRD parts. I can see if I can get some discount for the people on here, what you all think? Big Grin Big Grin
11-02-2004, 06:43 PM
Coilovers etc...
Well, if you would be so kind to see what kind of prices you can get on rear lowering springs from trd that would be great. I have a feeling that mux's apex springs have a rate around 3kg/mm. Not a problem for the rear of the car, you just need +/- 5.5kg/mm front springs to reduce the rolling in the front.
11-02-2004, 07:53 PM
Coilovers etc...
Mux first stiffen the Koni's that will help alot ther probally low set.
Stiffen them full than turn them a quarter open
11-03-2004, 12:46 AM
Coilovers etc...
Robo, That would put them on 7/8th strength. That will kill em for sureSmile
I want a good balance between my shocks, stabilizer bar and springs. I dont want to use my shocks for what my springs are supposed to do or the other way around. It'll just wear them out.
Also I need to play with demper settings front2back. Setting front 2 max will only keep the car understeered.
  Carina drivers! - Coilovers for a TA60/62 nyberrg 2 6,561 06-05-2017 10:03 AM
Last Post: nyberrg
  Fitting driftworks CS2 coilovers bozu 2 4,924 05-30-2017 10:50 AM
Last Post: bozu
  D2 Coilovers any good? heshan 18 27,205 04-04-2017 02:40 AM
Last Post: hachirokkos
  Has anyone tried BC Racing coilovers? AlexKTM 9 12,433 09-05-2016 12:28 PM
  Anyone running DIY Coilovers? Rasteirinho 8 14,058 11-19-2013 10:30 PM
Last Post: totta Crolla
