Coilovers etc...
11-02-2004, 11:28 AM
Coilovers etc...
Hey Guys,
Okay I finally found out what sorta springs I have. Standard APEX ones. The guy who had the car before me can't remember the spring rates but I believe they only came around 3kg. So I'm thinking of going different springs to fix my role problem. Now Ivan suggested I'd take a look at the coil overs from Paradise Racing. Zax has them aswell I think. They are for the front suspention only so I need to figure out what to do at the rear. Anybody got some advise on their experience with this setup? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
11-02-2004, 01:52 PM
Coilovers etc...
Try thicker swaybars first. It might wash the problem away.
11-02-2004, 03:00 PM
Coilovers etc...
Dont use thicker swaybars...you have a lack of springrate at the moment. Buy the swaybars if 6kg/mm springs arent strong enough.
[btw, I fiddled with the topic title a bit..it had some spelling errors ] FABRICA MI DIEM, PVNC! |
11-02-2004, 04:34 PM
Coilovers etc...
Did you buy new bushings for your swaybar? That might do the trick I kind of have the same problem and I use TRD Competetion springs and shocks
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
11-02-2004, 04:48 PM
Coilovers etc...
Bought yes
installed no Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
Coilovers etc...
Well..the prothane bushings have arrived so those wont take long to get under his car..
11-02-2004, 06:17 PM
Coilovers etc...
mux213 Wrote:Hey Guys,Get some TRD spring for the rear. You can get them for either short stroke dampers (Thats what I use) or lowerd height. You should be able to order them in different spring rates. Check here: http://www.trdparts.jp/list_ae86.html You can order them from TTE in Germany, they supplied me with most of my TRD parts. I can see if I can get some discount for the people on here, what you all think? |
11-02-2004, 06:43 PM
Coilovers etc...
Well, if you would be so kind to see what kind of prices you can get on rear lowering springs from trd that would be great. I have a feeling that mux's apex springs have a rate around 3kg/mm. Not a problem for the rear of the car, you just need +/- 5.5kg/mm front springs to reduce the rolling in the front.
11-02-2004, 07:53 PM
Coilovers etc...
Mux first stiffen the Koni's that will help alot ther probally low set.
Stiffen them full than turn them a quarter open Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-03-2004, 12:46 AM
Coilovers etc...
Robo, That would put them on 7/8th strength. That will kill em for sure
I want a good balance between my shocks, stabilizer bar and springs. I dont want to use my shocks for what my springs are supposed to do or the other way around. It'll just wear them out. Also I need to play with demper settings front2back. Setting front 2 max will only keep the car understeered. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 6,047 |
06-05-2017 10:03 AM Last Post: nyberrg |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,517 |
05-30-2017 10:50 AM Last Post: bozu |
D2 Coilovers any good? | heshan | 18 | 25,543 |
Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 11,696 |
09-05-2016 12:28 PM Last Post: mad.matt |
Anyone running DIY Coilovers? | Rasteirinho | 8 | 13,365 |
