Coilovers with Konis???
07-11-2005, 03:41 PM
Previous owner of my AE86 just told
me that the car has handmade coilovers in the front. I asked him if I use short stroke AE92 dampers, and he said no 'cause: "Koni made dampers -with oil- for the AE sold as a kit with Eibach short springs" Can that be true? And if I really have front coilovers wich dampers can I use? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
07-11-2005, 03:51 PM
Toyota Corolla AE92 Koni Sport (yellow) btw filled with gas, not oil.
Part number 8641-1146Sport Used on my, kris and so on drift ae86. Drifting - best fun you can have in your car with your pants on! |
07-11-2005, 04:55 PM
Thx ZaX,
but did Koni made the set I mentioned in the past? Plus, you have also coilovers in the back? If no, what to use, koni also (not coilovers)? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
07-11-2005, 05:10 PM
In the back you could use the normal ae86 Koni shocks, but I think it would be better to find some kind of short stroke alternative for the rear as well when your lowering the car alot (to avoid springs coming loose when unloaded)
07-11-2005, 06:03 PM
Ivan141 Wrote:In the back you could use the normal ae86 Koni shocks, but I think it would be better to find some kind of short stroke alternative for the rear as well when your lowering the car alot (to avoid springs coming loose when unloaded) Is there a short stroke alternative? I got no money for rear coilovers right now... P.S.: Nobody telling me if Koni made this oil kit dampers - Eibach spings, I was told about! danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
07-11-2005, 07:24 PM
HTS
Broken down 1984 Trueno HB ![]() |
07-11-2005, 07:28 PM
Aico Wrote:HTS You meen Tokiko? With what springs? They work good with front coilovers? How much do they cost, cause I have trouble finding them here in Greece. danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
07-11-2005, 08:14 PM
HTS is import only. They are SS and good for coil-overs.
07-11-2005, 08:50 PM
No man, no!
I asked for a -non coilover- damper kit for the rear, that works gook with coilovers at the front! danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
07-11-2005, 11:56 PM
Ooh sorry. Didn't read the entire thread. Anyway the HTS can be sold for the rear only and it's a normal damper. No coil-over.
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 6,565 |
06-05-2017 10:03 AM Last Post: nyberrg |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,927 |
05-30-2017 10:50 AM Last Post: bozu |
D2 Coilovers any good? | heshan | 18 | 27,238 |
Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 12,442 |
09-05-2016 12:28 PM Last Post: mad.matt |
Anyone running DIY Coilovers? | Rasteirinho | 8 | 14,067 |
