Compression test
01-07-2008, 10:50 PM
Compression test
These are the compressions for my bluetop (psi)
cylinders 2,3,4 showing 125 and cylinder 1 showing 175
Any thoughts about the condition of the engine ??
01-08-2008, 05:50 AM
Compression test
Did you do the test when the motor was warm or cold?
How many cranks of the motor per cylinder did you do?
If the test was done when warm then this would be an indication of excessive carbon buildup in the engine. It can only be corrected by performing a chemical de-carbonizing process on the engine or by removing the cylinder head and physically removing the carbon that is attached to the cylinder portion of the head and the tops of the pistons.
Could also be blown head gasket.
[Image: AEU86 AE86 - Compression test]
Corolla Levin SR 1984 AE-85 (Project car)
Corolla Runx Z 2002 (Runabout)
01-08-2008, 08:49 PM
Compression test
Rick Wrote:Did you do the test when the motor was warm or cold?
Test was done with a warm engine. Don't know how many cycles it went through though.
I intend to take the head off, is there anything to watch out for when doing this or is it fairly straightforward ?
01-08-2008, 10:29 PM
Compression test
taking the head off is pretty easy.. just remember to use one of those 12-sided sockets on the headbolts (size: metric 10), and keep track of what went where.
  82mm Stock compression Pistons apardal 4 2,871 11-24-2021 04:26 PM
Last Post: apardal
  working out compression ratios kazi 2 3,605 07-16-2019 08:22 PM
  How to test coil with igniter DJexor 2 7,915 03-22-2018 10:01 AM
Last Post: Project D
  Comp. Test - 20v Blacktop hachirokkos 2 4,832 01-10-2016 02:30 AM
Last Post: hachirokkos
  What is cranking compression on 10-1 4AGE? oldeskewltoy 2 4,748 03-24-2015 10:18 AM
Last Post: ditn
