What is cranking compression on 10-1 4AGE?
03-16-2015, 10:22 PM (This post was last modified: 03-16-2015 10:23 PM by oldeskewltoy.)
9.4 to 1 compression 4AGE has a 179# measurement, while the 10.3 to smallport 4AGE has a 190# measurement.
What is the cranking compression on a 10-1 4AGE - looking for a FSM reading/reference - I can guess and say 185 or so, but I was hoping for a measurement from the FSM
anyone?????
Dan -
03-23-2015, 06:09 PM
When mine was running it was putting out from memory, 182-183
My compression is not standard but it's about 10.15
03-24-2015, 10:18 AM
I knew an engine which only had 10000km
He did a warm compressiin test and had 187 on all cylinders complete stock
  82mm Stock compression Pistons apardal 4 3,137 11-24-2021 04:26 PM
Last Post: apardal
  working out compression ratios kazi 2 3,856 07-16-2019 08:22 PM
  Distributor position and cranking pack 13 20,236 07-01-2013 11:08 PM
Last Post: pack
  What fuel are you high compression guys running? 4000GT 18 17,339 09-04-2011 07:11 PM
Last Post: IBMFD3S
  7age 16v compression Pif 1 4,862 10-12-2010 09:37 PM
Last Post: Pif
