Corolla GT Coupe - Royalty Black
07-01-2015, 11:59 AM
Post: #181
Hey!
I'm using Mini Cooper S discs with custom made adapters made by a friend of mine that works with CNC. He also made the backplate adapter to use the 4AGE 16V rear water outlet. If you need i think i have the specs of my discs! ![]() |
07-01-2015, 12:05 PM
Post: #182
You need Mini R50, R52 or R53 disks which are 276mm diameter. They also need to be redrilled to fit the AE86 PCB.
07-01-2015, 01:03 PM
Post: #183
Yup! Thats right! 4x96 i guess it is the correct measurement.
07-02-2015, 12:23 AM
(This post was last modified: 07-02-2015 12:26 AM by isac.)
Post: #184
(07-01-2015 12:05 PM)d3nso Wrote: You need Mini R50, R52 or R53 disks which are 276mm diameter. They also need to be redrilled to fit the AE86 PCB. And need custom machined center rings to center mini brake discs because center diameter are to big and you don't want than floating or seat on hub bolts. Could result on lot of vibration. I bought these ones http://www.lott.de/autoteile/_MINI/BREMB...09663.html |
08-03-2015, 12:32 PM
Post: #185
Well....
The car is fully assembled....... Not started yet.... First problem was my Starter..... After cranking it went crazy cranking by itself even with key off...... Something is wrong there..... After replacing my starter.... The car cranks... but no fuel pressure..... I think my COR is not getting power feed..... It gets STA signal and 12V from IGN (i think i need to wire the +B wire of the T plug onto de +B from C plug to the ECU) as i talked with Isac yesterday.... Also the igniter needs to be grounded for spark! ![]() I'm not getting spark at all......... And i need to re-adjust the timing on my cam..... Anyone with the corrected position of the cam? Regards |
08-05-2015, 01:20 PM
Post: #186
Yesterday work....
Connected the 16V +B wire from T plug (Yellow) to +B from C plug (Black) taht also powers all the system and ECU. Fuel pump ON when cranking. CHECK! Now spark... No spark yesterday..... Jumped TE1 and E1 and BAM! Error 14 on the light... No IGF signal from Ignitor. So.... with some help i measured the continuity and no signal from the multimeter...... Next! Spark! ![]() |
08-05-2015, 05:28 PM
(This post was last modified: 08-05-2015 07:53 PM by ditn.)
Post: #187
Did you ground the igniter module,from a blacktop it must be grounded!
is there a signal coming from ecu from IGN ? |
08-06-2015, 12:11 AM
Post: #188
Yup!
It was the wire from IGT... must be broken or something.... Will get it sorted out tomorrow... Made spark, and some explosions on the exaust..... So... sorted out! Jumped TE1 and E1 and no error codes found ![]() |
08-07-2015, 05:41 PM
(This post was last modified: 08-07-2015 05:41 PM by pack.)
Post: #189
Habemus 86!
08-07-2015, 05:46 PM
Post: #190
![]() At last ![]() |
Gtsi-R red'n black coupé | Gtsi-R | 147 | 134,156 |
02-03-2022 02:43 PM Last Post: Ivan141 |
my 8a9 corolla GT coupe | cloko | 24 | 43,396 |
01-30-2012 05:17 AM Last Post: Sambo |
My UK TE71 Corolla SR Coupe Finished.... | japclassics | 8 | 17,225 |
01-11-2011 02:12 PM Last Post: Pacsker |
my 1984 red over black corolla gt | davegtcoupe | 3 | 10,618 |
10-12-2010 08:14 PM Last Post: davegtcoupe |
RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 31,564 |
User(s) browsing this thread: 22 Guest(s)
