Corolla GT Coupe - Royalty Black
08-27-2015, 11:02 PM
Post: #201
Bit late but thats really weird.
is the iscv properly installed? Is the white vacuum thingy for the map sensor installed correctly? |
08-28-2015, 01:08 AM
Post: #202
It was a vacuum pipe really cut off! Solved.....
I just have the ISCV not working.... i can't cycle from cold start to idle..... The pump is stuck somewhat on open.... ![]() I just idle for 1500.... when i close the air to the ISCV i can idle for like 900.... After that i can't do a cold start again..... ![]() Guess i'll have to buy one.. |
09-28-2015, 11:34 PM
Post: #203
It was about time to hit the tracks......
Last saturday was a great day! Finally the time to test my car! The damn suspension sux! Koni Sport and Apex were great on the 110Hp range... With the blacktop i need more..... Some pictures.... ![]() ![]() My girlfriend converted... ![]() Pr0n! ![]() ![]() And on the 26November we have more! Algarve circuit time! |
10-02-2015, 01:48 PM
Post: #204
congratulations!
Rising Sun T |
12-11-2015, 06:12 PM
Post: #205
Well.... 1000km's later.... the car started smoking and the 3rd and 4th cilynders don't look so good...
Still need to make a compression test to check my car up, but i think because it was stopped for a long time the piston rings aren't doing what they suppose to do.... Will spare my car from high revs and high mileage... and start building my spare parts a bit more... As i checked i already got the contacts to rebuild the engine properly... Will do it like properly and will change it all...... New oil pump, New valve stem seals New Headgasket New piston rings New engine bolts New piston rings The crankshaft and cylinders will be re-machined properly if needed..... Just want a decent engine... |
12-30-2015, 02:28 AM
Post: #206
Hi Pack, the Trueno is looking stunning, it's a shame that the engine began to fail after such a little mileage
![]() ![]() Btw, do you have in mind any specific setup for the suspension? |
12-31-2015, 01:40 AM
Post: #207
headrush, thanks!
This thing with the engine was a low blow.... but i can get past it... soon it will roll again! Yeps i have something on my sleeve.... I think i'm moving to BCracing and will overhaul them with bilstein material... 6Kg springs (Swift) in the front, 4.5Kg in the back Cusco sways on both sides Basically this is it... |
12-31-2015, 08:08 AM
Post: #208
You might want have a look at Schockworks from Australia, would allow you to skip the overhaul part and they already come with the soft springs
AE86 ex-daily |
12-31-2015, 11:06 AM
Post: #209
Or simply order BC Racing coilovers with 6/4.5KG springs. No need to modify them as they can be configuered as you want.
12-31-2015, 04:58 PM
Post: #210
If got bc racing in my car (5kg in the front and 4.5kg in the back)
I'm very happy with them. grtz |
Gtsi-R red'n black coupé | Gtsi-R | 147 | 134,032 |
02-03-2022 02:43 PM Last Post: Ivan141 |
my 8a9 corolla GT coupe | cloko | 24 | 43,365 |
01-30-2012 05:17 AM Last Post: Sambo |
My UK TE71 Corolla SR Coupe Finished.... | japclassics | 8 | 17,202 |
01-11-2011 02:12 PM Last Post: Pacsker |
my 1984 red over black corolla gt | davegtcoupe | 3 | 10,611 |
10-12-2010 08:14 PM Last Post: davegtcoupe |
RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 31,488 |
