08-08-2007, 09:33 AM
Post: #371
wiseco high comp pistons ?????
08-08-2007, 04:48 PM
Post: #372
Yes, Wiseco.
Best regards |
08-10-2007, 03:31 AM
Post: #373
Quote:Why are you holding a file??? That's some scarry sh**! Maybe to punch down the piston, with the wood block i think. Never thought tha wiseco pistons would have such deep valve "holes". Looking good Cump´s Filipe Oliveira |
08-10-2007, 05:15 AM
Post: #374
Looks very nice!
I almost feel like going to the bank tommorow, take up a large loan, and start re-building a hachi myself ... I think I would have to get another AE86 first, with black interior... don't like my blue interior :-/ |
08-10-2007, 02:02 PM
Post: #375
The file was used to modify the top ring gap. Was to tight for this engine application.
Best regards |
08-10-2007, 02:42 PM
Post: #376
look , my hand
that file was for both things, file the top ring ( to increase gap ) and with the wood part to punch down the pistons into the block |
08-13-2007, 11:47 AM
Post: #377
Hi! First 30 miles below 3000 rpm have ran already without any flaws from the engine. To repair is a noise (clunk when lightly tapping the accelerator and rasping at certain rpm's) that sugests excessive backlash between the gearbox and rear axle. Rear axle was assembled by the book, with new bearings and solid spacer with all backlashes within spec.
I've installed a whiteline panhard bar (that is not very easy to adjust) and I've read that I should have loosen the driveshaft center bearing bolts. Gonna try that as soon as I get home tonight. Anyway, I'm gonna run another ~100 miles gradualy revving the engine until 5000-6000 rpm and then I'll change the oil to Castrol RS 10W60 and replace the oil filter. The Greddy Suspension is not that harsh and gives a nice ride. I haven't really tried it hard, but the first impression is good. My kidneys might survive! Best regards |
08-16-2007, 11:58 PM
Post: #378
140 miles... looking good so far.
Assembled the Apexi SAFC and started tuning it. It seems easy to work with and the results come quick. I might think of bigger camshafts in the meantime. This is the last picture of the car. The only problem left to solve right now is an excessive backlash (with a clunk sound, but not the same has the tomei lsd) from my rear end that I think comes from the half axles, but I'm not sure. The ring and pinion (4.77 were installed by the book and had no excessive backlash, new bearings, etc. Along with this, is a vibration sound that appears when I decelerate and the car rolls in gear at 3000 rpm or so. Don't really know whats wrong and if it is related to the backlash. Best regards |
08-17-2007, 12:20 AM
Post: #379
Nice Levin,love the Panda body paint anytime anyday...
08-21-2007, 06:58 PM
Post: #380
Great Panda Levin André!
Keep up the good work! See you and that nice 86 in September! 86'LEVIN Track Project |
Toyota Corolla AE86 LEVIN ( Poland) | sylwekgtir | 40 | 54,345 |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 14,829 |
RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 30,996 |
Shell make over a coat of paint | williep12 | 4 | 6,971 |
Repair/ Body | whitepoint | 6 | 8,221 |
03-12-2008 09:21 PM Last Post: whitepoint |
