Correct connection brake master cylinder?
07-19-2015, 08:43 PM
Gents,
I'm currently rebuilding my car and recently installed a new brake master cyl. Just want to double check if it is connected properly now to the proportioning valve block. See picture below, can someone confirm? AE86 Levin |
07-23-2015, 06:28 PM
No one?
AE86 Levin |
07-23-2015, 10:38 PM
AE86 ex-daily |
07-24-2015, 07:31 AM
The side connection of the bmc goes to the left top of the proportioning valve and de back connection of the bmc goes to the left bottom of the proportioning valve
AE86 Levin |
07-25-2015, 03:45 AM
AFAIR there are letters casted on valve... look them up.
07-26-2015, 12:28 PM
(This post was last modified: 07-26-2015 12:30 PM by bozu.)
I'm only interested in the connection with the bmc. The other ones ive got.
On the left top of the valve there is a 'F' and left bottom an arrow pointing in to the valve. I would assume F stands for feed but why is there also an arrow pointing in. On the bmc there is a letter on one port which looks like an F or a P. Ive connected that port to the F on the valve. Ive already tried to look it up in the manual but no luck. Hence why i'm asking here. Just want to double check, don't want to have to change it after everything is bled. AE86 Levin |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,170 |
Brake advice - master cylinder | mannix20vt | 12 | 14,344 |
torque setting head cylinder bolts | izanagi | 1 | 4,974 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
Dimensions clutch master cylinder | bozu | 2 | 6,178 |
04-16-2015 07:11 AM Last Post: bozu |
Oil leak (maybe a cylinder head gasket?) | max_ae86 | 15 | 17,369 |
11-30-2013 03:59 AM Last Post: jondee86 |
