Custom Dash Cluster
10-14-2017, 05:27 PM
Custom Dash Cluster
Hi all.
So I've been having an issue wth my dash Mainly the dash back lights not working. and i thought that seeing as the RPM and speedo isn't the most accurate on the 86 i would do a custom cluster. Something like below. ae86 cluster by ae86-kazi, Question i have, Is there anything (wiring wise) that i need to take away? do the block connectors at the bottom of the OEM gauge stay etc etc? TIA |
10-14-2017, 06:29 PM
Custom Dash Cluster
+++1 -Very interested as my cluster is completely dead.
10-14-2017, 09:03 PM
Custom Dash Cluster
I would say it all depends on the gauges you are going to use...
First of all: if you are creating it from scratch, you probably are going to either use the existing header (male connector) and your current cluster, or splice out the original female connector and wire it in separate connector pairs for each gauge. It also depends on what type of gauges you are going to use: the fuel gauge of the AE86 is basically an ammeter, so replace it with an gauge that is measuring resistance and not one that is measuring voltage. (or use the OEM one like in your photo) I believe the same applies to the oil pressure sensor: it is resistance based. Also the speedometer of the AE86 is cable operated (also on the digital gauge clusters), so if you would use a digital item like in the picture above the easiest would be to go for a rotational sensor on the propshaft. That would mean you have to install a new wire for that as well. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
10-15-2017, 04:15 PM
Custom Dash Cluster
Thanks Banpei.
Gauge wise, i would prob go Defi or Stack. I would leave the OEM fuel gauge but replace the oil press and engine temp wth aftermarket. Could the RPM and Speedo not be wired directly into the ecu? I'm currently running and apexi RSM so i know what speed etc I'm doing and thats how I've done it. |
10-15-2017, 08:44 PM
Custom Dash Cluster
Why not run something like this? 1 unit that runs everything except the fuel level?
Sent from my F3111 using Tapatalk |
10-15-2017, 11:11 PM
Custom Dash Cluster
Pretty sure the ECU gets the speed (SPD) signal from the factory
speedo, not the other way round. And your vehicle regs most likely will say you have to have a tamperproof odometer. Probably why your pic shows an old school mechanical odo above the digital speedo. Might be a good idea to check that out with your MOT inspector. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
10-15-2017, 11:30 PM
Custom Dash Cluster
Cost mainly Miggzsf. This would be an idea situation but they are over £1k in most cases
10-16-2017, 08:58 PM
Custom Dash Cluster
(10-15-2017 11:30 PM)kazi Wrote: Cost mainly Miggzsf. This would be an idea situation but they are over £1k in most cases bud send me a whatsapp lets see what i can get it for you my number +27824599102 |
10-17-2017, 08:50 AM
Custom Dash Cluster
I dont understand why you would prefer this over just fixing your stock cluster.
Have you really checked everything there is to check? It might be a really small thing. FABRICA MI DIEM, PVNC! |
10-17-2017, 11:39 AM
Custom Dash Cluster
(10-17-2017 08:50 AM)Ivan141 Wrote: I dont understand why you would prefer this over just fixing your stock cluster. I have check everything there is to check. Currently the clocks are stripped down as much as they can be. My next step would be to get a replacement set of clocks, But giving that the 86 clocks aren't the most accurate in terms of tacho and speedo, then the next things to do would be to get aftermarket gauges. |
Digital Dash | evfan42 | 190 | 257,433 |
05-03-2024 06:44 PM Last Post: banpei |
EUDM gauge cluster | banpei | 22 | 4,009 |
08-15-2023 10:48 PM Last Post: banpei |
EUDM cluster revelations | banpei | 1 | 1,196 |
06-23-2023 09:11 AM Last Post: r.ave |
Dash Waning Lights | pack | 7 | 4,045 |
10-06-2021 01:00 PM Last Post: pack |
Trueno Digital dash kph to mph | Bojack | 3 | 6,826 |
11-21-2018 12:27 AM Last Post: kazi |
